Author Topic: Whats the Cord Length on a GroovyGameGear USB Hub?  (Read 1818 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: September 16, 2005, 04:35:08 pm »
I am interested in using a USB hub now for my portable control panel.  It will have a USB trackball, USB spinner, USB GPwiz49 encoder and a USB IPAC2.
It would be great to have only ONE cord coming out the back of the CP not 4!!!   I have been told to check out the USB hub offered at www.groovygamegear.com but I want to know:
How long is the cord on the USB hub?
also.   dust washers.   GGG has those also.  I tried to refit my Happ Supers with Stainless Steel ball top joysticks and the hole in the middle of the dust washer was MUCH TOO BIG for the new sticks.
Question 2:  Would the dust washers that GGG sells fix that problem?  Do they fit ball tops better than supers?
Thanks again!
RandyT
  • Last login:Yesterday at 03:05:01 pm
    • GroovyGameGear.com
Re: Whats the Cord Length on a GroovyGameGear USB Hub?
« Reply #1 on: September 16, 2005, 10:41:50 pm »
It's only about 3 feet.  If you need more cable, an extension will probably be in order.
If you bought the shafts from GGG, then yes.  Otherwise, dunno.  Do you have the diameter of the shaft?
RandyT
