Author Topic: New Layout AtomicFE online  (Read 2042 times)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« on: September 12, 2005, 04:58:48 pm »
Hi,
A nice "Street Fighter" layout (including a background music) for Atomic FE is online ,
bdsjake
  • Last login:September 18, 2017, 12:08:23 am
  • livefree
Re: New Layout AtomicFE online
« Reply #1 on: September 12, 2005, 09:24:03 pm »
Hi youki, do you have any vertical layouts 288x640 (for a standard arcade monitor/ArcadeVGA setup).
thanks,
CM
  • Last login:January 02, 2012, 08:59:17 pm
  • The internet?!? Is that thing still around?
« Reply #2 on: September 12, 2005, 10:09:13 pm »
Am I the only one thinking "Fighter Orgy" for this layout?  ;)
youki
    • Atomic Front End
« Reply #3 on: September 13, 2005, 04:06:21 am »
I have only 2 i think a not very nice it was some layout i did as "sample" at the begining of Atomic. And unfortunaly user don't send me lot of "pure" vertical layout.
But with Atomic , you can use horizontal layout in vertical mode.  you can for instance use a horizontal 800x600 layout , in vertical in 288x640 , Atomic rotate and strech for you.  Of course ,due to the streching and the rotate you lost quality and aspect/ratio. But it works.
Just select a layout in AtomicManager, and on the general tab , enter the resolution of your screen (as it was horizontal for 288x640 entrer 640x288  and choose as orientation "vertical".)
(For "pure" vertical layout, the orientation must be "horizontal")
bdsjake
  • livefree
« Reply #4 on: September 13, 2005, 10:22:30 am »
youki, thanks, I'll try it out soon.  When it comes to vertical at this resolution, I'm just looking for somethign that *works* doesn't have to be the prettiest.
