Author Topic: Light Guns  (Read 2193 times)
SithMaster
Light Guns
« on: September 11, 2005, 11:56:16 pm »
Want that real light gun feel.  Does anyone recommend a pc light gun?  Thanks.
Acorn
  • Last login:February 12, 2006, 03:04:58 pm
  • Lightguns!
    • WinGun Driver
Re: Light Guns
« Reply #1 on: September 12, 2005, 12:11:24 am »
At this point in time, you have three choices.
You can use one of the existing PC guns - the only worthy one being the ACT-LABs gun (see reviews of PC-lightguns HERE). These are pretty expensive ($100 range), and at the current time you either have to get them on ebay or sign up for a pruduction run that may or may not occur.
Your second option is to wait for the camera guns to come out, they are supposed to sometime in december. The good of these are they don't require a specific screentype. The bad is they are very inaccurate and cost $79.99. And just like the ones above you have to wait.
The best option is to buy a Guncon2 compatible gun (yes, the playstation 2 guns) for which you can use a driver on the PC. With the amount of PS2 lightguns around you can choose from any style you want. See HERE for more information. There are a couple of reasons not to take this approach: the drivers are not commercial so there is no commercial support, and the guns do not work on a PC monitor (with 31khz horr refresh) without a hardware circuit (although this circuit is now available). They do work on arcade monitors, CRT TV's, and even some of the PS2 guns work with projection TV's.
Do your research carefully, and feel free to ask any questions you may have!
Get WinGun (Guncon 2 PC USB Driver) at http://www.guncon2driver.com
SithMaster
Re: Light Guns
« Reply #2 on: September 12, 2005, 02:35:00 pm »
i plan on using a pc monitor that is 17" future power 17db06.  i have a ps2 to usb converter that i used with a playstation pad for a while.
is the mad catz blaster good to use with a pc monitor and does it work with most mame light gun games?  thanks
Pik4chu
  • Last login:April 09, 2012, 01:35:17 pm
  • So what was I supposed to put here?
Re: Light Guns
« Reply #3 on: September 12, 2005, 03:34:32 pm »
