Author Topic: LuSiD's Plans Can I Get Inside?  (Read 1550 times)
JONTHEBOMB
  • Last login:March 28, 2025, 11:39:04 pm
  • BOOM!!!!
« on: September 11, 2005, 05:39:29 pm »
Hello,
I am using LuSiD's Plans to build my cabinet.  I have my wood and will be soon getting the other supplies.
1. What I'm wondering is if I don't hinge the cabinet front will I be able to get into my cabinet when it's finished to put a computer inside?
Or should I maybe hinge a piece on the back for access?
2. Another quick thing is if I am going to use a 21 inch PC monitor I just need to switch all the 26 inch measurements to 22 inch measurements and I should be ok right?
Thanks again (I'm just a little worried about screwing something up.)
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: LuSiD's Plans Can I Get Inside?
« Reply #1 on: September 11, 2005, 06:07:19 pm »
1: Not easily. You can go in through the back (if you hinge it) or you can remove the CP and go in through there (not very big).
2: I think so, but be sure to change the CP size to fit.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
Jabba
  • D-Hutt
  • Last login:November 16, 2020, 02:17:20 pm
  • I find your lack of faith...disturbing...
« Reply #2 on: September 11, 2005, 06:26:15 pm »
I used the Lusid plans to build my cab.
Originally, I hinged the front and back, but after some use, I decided I did not like the look of the hinge on the front (never saw a real Arcade cabinet like that) and decided to screw the front panel it down.
I access the computer from the back hinge now. No problems at all. I put my cab on caster wheels and just wheel it forward from the wall when I need to access it. If you put your cab on hinged, shorten it by 2 - 3 inches.
I can power the unit on and off through the coin door when I need to get in that way. My computer will not power on when I turn on the main cabinet power. Something with the BIOS.
As far as the dimensions go, I would just leave it at the current size in the plans. Who knows, maybe someday you will inherit a larger monitor.
« Last Edit: September 11, 2005, 06:32:11 pm by Jabba »
Vids:  Home built MAME machine, Crystal Castles. Arkanoid
Pins:   Williams Aztec (working). Stern Nugent (not working...yet), Williams Phoenix (major not working, missing parts.... )
Always on the lookout for buying 90's game with Ramps that need work...
