Author Topic: i just made a marquee do i have to have it  (Read 1488 times)
janey
  • Last login:August 06, 2016, 02:36:23 pm
  • I want to build my own MAME / Hyperspin cab
« on: September 10, 2005, 11:46:55 am »
Vectorize , in order to print out ??/
Or what do i have to do to print out  say 24" long x 10 high
can someone  explain how exactly what do i have to do in order to get clear printing results ..
thanks
janet
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
Re: i just made a marquee do i have to have it
« Reply #1 on: September 10, 2005, 07:24:06 pm »
Depends on what resolution you created it at...  If I were going to use non-vector art, I'd probably shoot for 300 dpi for the artwork, but I think I've read some people say as low as 150 will produce acceptable results.  If you created your artwork at a lower resolution than that, you'll have to redo it at a higher resolution.  There's no real way to scale up low resolution artwork and have it print well - that's why the vector art is so popular around here.
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
Crowquill
  • Last login:March 30, 2026, 01:03:12 pm
« Reply #2 on: September 13, 2005, 11:44:41 am »
On the DesignJet that I print with at Kinko's (I work there), even 100dpi will give acceptable results. I definitely would recommend keeping it higher, but if it's at 100dpi (at full size) or higher, I don't know if it's worth re-doing from scratch.
Most Kinko's use this same printer.
« Last Edit: September 13, 2005, 11:46:26 am by Crowquill »
