Author Topic: Mamewah Vs. Mame32 resolution issues - need Mamewah help.  (Read 1345 times)
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« on: September 09, 2005, 10:41:51 pm »
***EDIT: Problem Solved
Here's the scenario:
I used to play all my games on a big ol CRT that will display any resolution.
« Last Edit: September 10, 2005, 01:37:15 am by timoe »
wast3d
  • Last login:November 30, 2005, 03:43:00 pm
Re: Mamewah Vs. Mame32 resolution issues - need Mamewah help.
« Reply #1 on: September 10, 2005, 02:12:13 pm »
What did you have to change to fix the resolution problem? Might be helpful if some one else has the same problem.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #2 on: September 10, 2005, 06:47:24 pm »
I had my mame.ini 's set like so
match refresh rate 1  (I had to change the 1 to a 0)  And a few others like that.
 I already knew that my mame32 would play everything and my "command line" mame was having problems.  So I opened up both .ini files (mame32.ini and mame.ini) and put them side by side on my desktop and I just went down the list to see where the differences where.  Obviously I focused on the video options because thats where my problems were.
hope this helps someone.
