Author Topic: T-Stick Plus, interesting find!  (Read 1439 times)
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« on: September 07, 2005, 12:56:09 pm »
I was messing around with my T-Stick plus yesterday and I came to realize that you could convert it to diagonal mode just by flipping over the four microswitches.
The joystick is mounted to the control panel just as it normally would for your standard 4-way and 8-way games.  The only difference is that the microswitches are flipped over and mounted in the opposite direction.  For diagonal mode you just leave the restrictor in 8-way mode.
Now you can play Q-Bert and Congo Bongo properly without too much hassle.
Patent Doc
  • Last login:March 25, 2021, 12:07:33 pm
  • My wife says I'm the fastest man alive :(
Re: T-Stick Plus, interesting find!
« Reply #1 on: September 07, 2005, 01:38:39 pm »
OK, I admit I don't have a T stick plus, but I'm not following how this would help.  All you would be doing is reversing the direction of the actuators.  Maybe I'm totally missing something, but how does that change the joystick from 4-way/8-way to 4-way/diagonal?
Patent Doc
NoOne=NBA=
« Reply #2 on: September 07, 2005, 06:46:52 pm »
It actually rotates the switches 45 degrees out from where they normally are.
Scoobie
  • Last login:December 26, 2024, 12:53:48 am
« Reply #3 on: September 07, 2005, 11:21:05 pm »
Or you could map the keys for those games so the diagnols are hit every time.  Worked great for me...
« Reply #4 on: September 08, 2005, 04:34:55 am »
Many people prefer the feel of a true diagonal stick however.
