Author Topic: Mamewah NES & Megadrive??  (Read 4028 times)
lettuce
  • Make It So!
« on: September 06, 2005, 05:14:05 pm »
Just been trying to set up these 2 emulators (FCEUltra & Kega Fusion ver. 3.3) to use with mamewah and have come across a few problems. When i have setup mamewah to use these emulators, FCE starts out in a window, if i go to video setting and set it to fullscreen, it comes up with an error message and say something about direct draw command is wrong, and closes the program. With Fusion i select a rom to load but it only starts up the emulator and doesnt load a rom, Could some please help me with these problems?
Re: Mamewah NES & Megadrive??
« Reply #1 on: September 06, 2005, 07:04:31 pm »
Not sure about the FCE problem....but for Fusion you need to use a commandline_format like:
"[rompath]\[name].[romext]" -fullscreen{nodosbox}{nosafelaunch}
lettuce
  • Make It So!
« Reply #2 on: September 07, 2005, 05:48:25 pm »
I placed that commandline in the ini file, now it loads the rom, but the screen it just black and i can hear the game but not see it, any ideas??
« Reply #3 on: September 08, 2005, 04:22:30 am »
Try {safelaunch} instead of {nosafelaunch}.
lettuce
  • Make It So!
« Reply #4 on: September 08, 2005, 11:09:02 am »
Ok ive try {nosafelaunch}, but now it does the same but instaed of a black screen it just stays on mamewah screen, and i can hear the game. What is the best SNES, NES, & GENESIS emulators to use with mamewah?
« Last Edit: September 08, 2005, 12:23:10 pm by lettuce »
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
« Reply #5 on: September 08, 2005, 05:17:56 pm »
Mamewah is a far better choice for all these Arcade/Console emulators and Pc games.
You can check the list here.
http://home.comcast.net/~cpviewer/downloads.htm
« Reply #6 on: September 08, 2005, 07:06:49 pm »
Fusion is best IMO - I use it personally.  For me however it works fine with the commandline_format I posted before.  Try using:
"[rompath]\[name].[romext]" -fullscreen{dosbox}{safelaunch}
That should certainly work.
lettuce
  • Make It So!
« Reply #7 on: September 09, 2005, 01:54:40 pm »
Yeah thats worked now, thanks. New problem though, hardly none of my MD screen shots show up, ive pointed mamewah to the correct directory it just does show hardly any of them, any ideas??
jcrouse
    • CPViewer
« Reply #8 on: September 10, 2005, 01:55:01 pm »
Well, if even one shows up it's not your ini file. THe path must be correct. Are your images named EXACTLY the same as the rom name?
John
« Reply #9 on: September 11, 2005, 07:12:38 pm »
That's probably it, many emulators do not follow the standard that MAME does (unfortunately).
