Author Topic: [UPDATED!]Patch for Atomic FE 0.14 on line  (Read 2800 times)
youki
  • Last login:October 12, 2025, 12:33:39 pm
  • Atomic Front End Creator
    • Atomic Front End
« on: September 05, 2005, 06:30:29 pm »
Hi,
A patch is on line on my web site : http://www.atomicfe.com
« Last Edit: September 07, 2005, 11:36:15 am by youki »
HighNoon
  • Last login:December 08, 2023, 08:21:37 am
Re: Patch for Atomic FE 0.14 on line
« Reply #1 on: September 06, 2005, 12:41:45 pm »
Youki,
Thanks for all the hard work, it is appreciated.  I've been looking for a way to start a specific game on startup, and was excited to try the new patch.
Unfortunately the patch does not work for me.  AtomicFE crashes and windows reports an error when I try to load a game.
I am running XP sp2 with mame32, AMD 1.7gHz, 512m ram, ATI 9800 Pro
I went back to the original AtomicFE files and it works again.
youki
    • Atomic Front End
« Reply #2 on: September 07, 2005, 08:12:55 am »
What was the error message from windows?
When you specified the name of the game to lauch at start , you gave it the Rom name (not the game name) without the extension?
HighNoon
« Reply #3 on: September 07, 2005, 09:59:05 am »
AtoMic.exe has encountered a problem and needs to close.  We are sorry for the inconvienience.
Error Signature
AppName: atomic.exe        AppVer: 0.0.0.0   ModName: atomic.exe
ModVer: 0.0.0.0   Offset 0000b81a
I did not specify a rom name, At the time I launced AtomicFE from within windows, using the default layout, it showed me the few roms I have in the left pane, I double clicked MsPacMan, and then I get the "prepare for battle" sound then the crash.
If I replace the patch files with the original ones, this same process works just fine.
I hope this helps, let me know if you have more questions.
Thanks again
youki
    • Atomic Front End
« Reply #4 on: September 07, 2005, 11:15:30 am »
Oups... i see what i did.
So , try that, in AtomicManager  , on the "general tab"  on the "controles" zone , select a "mouse /trackball" or "Mouse / Spinner" even if you don't use that.
It should solve your problem.
Sorry...  i'm going to fix that as soon as possible and update the patch.
thanks a lot for your feedback!  :)
youki
    • Atomic Front End
« Reply #5 on: September 07, 2005, 11:35:34 am »
Ok, i fixed it!..  I updated the Patch on my web site.
Now , the problem should be solved. Just download again the patch.
thanks for all.
Youki
HighNoon
Re: [UPDATED!]Patch for Atomic FE 0.14 on line
« Reply #6 on: September 07, 2005, 08:14:06 pm »
Yep, that did it.  It's working well now.
Does the help menu cover how to change the layout?  I browsed through it but I'm not sure.
Thanks again!
youki
    • Atomic Front End
« Reply #7 on: September 08, 2005, 03:49:00 am »
Yes, the help should cover that.
But you want to know , how to make a new layout ?
« Last Edit: September 08, 2005, 05:10:47 am by youki »
daywane
  • GRRRR!
« Reply #8 on: September 11, 2005, 07:16:59 pm »
COOL!
