Author Topic: Car Amp Sound Input  (Read 3418 times)
commandcom
  • Last login:February 11, 2006, 11:56:19 am
Car Amp Sound Input
« on: September 03, 2005, 08:38:39 pm »
Hey now,
I'm using a car amp to power the sound in my cab.  The plan was to cut one end of a standard 1/8" stereo patch cord and splice the ends into the left and right channels of the amp.  However when I cut the patch cord, I was surprised to see only three wires: red, black and an unwrapped silver wire.  I expected to see four wires: left channel + and -, and a right channel + and -.
So how does one get left and right channels from only three wires?  And yes, I'm sure the patch cord is a stereo cable: there are two black "bands" on the jack.
TIA
BobA
  • What Me Worry?
Re: Car Amp Sound Input
« Reply #1 on: September 04, 2005, 10:25:18 am »
The black and red are the left and right channel + and the silver is a common ground the - for both channels.
BobA
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #2 on: September 04, 2005, 05:17:30 pm »
Is that cable from an old car? older cars/cheap radios used to have common ground for the left and the right audio - not so often now...
If your amp has seperate +ve and -ve terminals for each channel (very likely) then I would suggest getting some speaker cable that has a seperate -ve and +ve - practically all speaker cable you can buy will, and its cheap.
Not sure how powerful the amp is, but if its high powered the common ground is not such a good idea.
commandcom
« Reply #3 on: September 06, 2005, 03:45:57 pm »
Ah, stupid me.  I should have realized.  Thanks for the info.
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #4 on: September 06, 2005, 03:47:20 pm »
It could always be a mono amplifier.
positive terminal
negative terminal
remote terminal (for remote turn-on)
Got a model name?
commandcom
« Reply #5 on: September 07, 2005, 05:48:45 pm »
The question concerned a cable/patch cord, not an amp.  It was just a run-of-the-mill stereo cord with 1/8" jacks on either end.  I was being stupid and not thinking the problem through  :P
webgeek
  • Last login:August 08, 2006, 07:05:10 pm
« Reply #6 on: September 08, 2005, 07:59:26 am »
You can also buy a 1/8" to component patch cable for a couple bucks. I'd personally suggest you go that way as you will get less potential noise on the line and you can get high quality jacks.
commandcom
« Reply #7 on: September 09, 2005, 04:40:06 pm »
Any idea where?  I looked for something like that at Radio Shack but, not surprisingly, they did not have one.
webgeek
« Reply #8 on: September 09, 2005, 04:45:24 pm »
I would have bet money that Radio Shack carried them but if not, try a Best Buy or equivalent store that sells audio equiptment. I picked up one a while ago but I can't remember where.
