Author Topic: Trackballs: Happ's Golden Tee V's standard happ's 3' TB (is there a difference?)  (Read 1700 times)
rackoon
  • Last login:February 16, 2026, 06:26:24 pm
  • I EAT PENCILS!
Yea,  I know,  use the search option.  (exhausted that resource allready)
      What is the deal with happ's Golden Tee trackball. Is it more heavy duty than Happ's standard 3' trackball? Is it better set up for faster spin? Will it take a beating ( from my drunken friends ) better  than a happ's standard 3" TB. Does it's high lip design set it apart from Happ's standard 3"? Or is it the adapter plate that sets it apart.
     I am going to buy a couple of TB ( from the P boy ) this week and  just want to be sure of what I'm buying. I have scoped out the happ's site well and am still confused.
    The thing is,  I want to buy a different  color than white. ( will the Happs 3" in (black) be of the same  quality as the Happ's Golden Tee TB.
                              Please help!
P.S. Will Star Trek make a come back? Can Star Trek make a come back with-out a sexy half-borg half-human chick? Is (main-stream) Sci-Fi possible without a hot chick? (Ya know it's not) don't lie, because (the lack of) sealed the death of Enterprise!
They treated me like an animal and that's what I became.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
Search "trackball high lip normal" and the top was to here.  And the ones down from that are pretty good too.  ;) (edit: I searched the same words again, and the top few changed just five minutes after the first search ???.)
The only difference between the normal and the GT TB is the top half of the case: .  So, yes the high lip is what "sets it apart", but not that much.  I believe happs has switched all TBs to the new red boards, so both have the same spin speeds.  The GT TB itself is not stronger or more rugged than the normal TB.
The mounting is a totally separate issue.  Both TBs can use either the normal 3" mounting plate or the GT heavy duty, and visa versa, AKAIK.  However, the GT mounting kit (aka "heavy duty mounting kit") is, surprise, more heavy duty.  It's also bigger.  Happs came out with it supposedly becuase the other mounting kit wasn't strong enough for repeated hits of the drunk in bars.
Since you're not buying directly from happs, will ponyboy swap the balls for you?
Robin
Knowledge is Power
rackoon
  • I EAT PENCILS!
Thanks rebelscum,
        You da man!
