Author Topic: lemme get this straight (rotary)  (Read 1903 times)
muttonchop
  • Last login:September 22, 2005, 10:17:29 pm
« on: August 31, 2005, 04:32:31 pm »
i have a new love for these rotary stick games.  lets say i get a hold of a pair, what EXACTLY will i need?
1. sticks
2??
had a little trouble with searching, then again, im retarded, so dont be too mad if this is a crazy known answer.
biocrack
  • Last login:June 04, 2007, 09:09:56 pm
  • Que viva el guaro
Re: lemme get this straight (rotary)
« Reply #1 on: August 31, 2005, 04:45:04 pm »
1 - Joystick
2 - and interface between the joysticks and the encoder (ipac, keywiz,etc), i recomend druin's interface
3 - have fun !
i hope this helps you
muttonchop
« Reply #2 on: August 31, 2005, 04:48:47 pm »
hmmm what encoder?
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #3 on: August 31, 2005, 04:53:58 pm »
Get a Keywiz encoder for for our joysticks and buttons from
www.groovygamegear.com
Or an IPAC2 keyboard encoder from www.ultimarc.com
Then get Druin's Rotary Interface from http://connect.to/rotary
You can also get a tutorial or instructions from druins website
« Last Edit: August 31, 2005, 04:55:59 pm by timoe »
Nannuu
  • Last login:May 23, 2022, 11:55:21 pm
  • Anytime now, I'll start my cabinet
    • Will and Liliana's Projects and Family Photos
« Reply #4 on: August 31, 2005, 04:57:31 pm »
I assume you are talking about mechanical rotaries (ie Ikari Warriors, Heavy Barrel).
« Last Edit: August 31, 2005, 06:21:55 pm by Nannuu »
Next I'll be on fries, and that's when the big money starts rolling in.
Nannuu
« Reply #5 on: August 31, 2005, 05:07:58 pm »
I think you still need an encoder with the 49-way route.  Druins will take up a lot of inputs so you'll probably need a second encoder just for buttons.
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #6 on: August 31, 2005, 05:26:42 pm »
Druins board should only take up 4 inputs.
Player 1 clockwise
Player 1 counterclockwise
Player 2 clockwise
Player 2 counterclockwise
muttonchop
« Reply #7 on: August 31, 2005, 11:08:27 pm »
ugh, so the druins board is for the twisty part...is it possible to wire these suckers to an optipac?  already have one of those,,,
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #8 on: August 31, 2005, 11:30:13 pm »
Fine then, just use a spinner and a joystick.   :P
Timoe
  • Team-Oh-tAy-Oh
    • Rattlin' Trash
« Reply #9 on: August 31, 2005, 11:34:56 pm »
The mechanical rotary will not work with an opti-PAC.  The OPTICAL Rotary Sticks might though but I dont know if that will allow you to play Ikari or not.
muttonchop
« Reply #10 on: August 31, 2005, 11:39:56 pm »
that sucks a big one
http://forum.arcadecontrols.com/index.php/topic,20018.0.html
yep, looks like im sticking with that.
although there are 2 snk sticks on ebay for cheap with no bids.....
still like 75 dollars i dont want to spend, then i need to make a new control panel, than i have to redo some wires to make it swappable.....
/wah
Nannuu
« Reply #11 on: September 01, 2005, 10:58:45 am »
If you get optical rotaries you can play Ikari with those.  It just doesn't have the same feel as the clicky mechanical.  You can also use them as a spinner.  So you'd have a dual spinner setup.  Granted the spinner joystick is not the greatest spinner in the world either.
muttonchop
« Reply #12 on: September 01, 2005, 03:07:10 pm »
ive been researching and i am going to get opticals soon.  ill also try to get a nasty spinner.
what feels better, a nasty (that sounds so bad =( ), or an easyarcadesolutions?
gmorse
  • Last login:July 01, 2007, 10:02:25 pm
« Reply #13 on: September 04, 2005, 02:15:40 am »
I caught this link a couple days ago and as luck would have it had a pair of T-Stick Plus arrived on Friday.   Spent $12 on parts and the better part of this afternoon putting together the rotary mouse hack  and what do you know, it works like a charm.  Took a little tweaking and a bit of frustration, but in the end it was well worth the time.  I was able to get further in Heavy Barrel than I had ever gotten before; scored 75000 in Discs of Tron (which was about what I scored on average in the arcade); tempest was very playable; pretty much every decent rotary/spinner/driving game was playable from APB to Ikari.
Now if I can only get a trackball hack to work, I'll be in business.
