Author Topic: Virtual drive not fooling XvT  (Read 5108 times)
JCKnife
  • Last login:November 04, 2008, 09:41:57 pm
« on: August 29, 2005, 05:21:20 pm »
Hey all,
I just starting mucking about with Daemon Tools and Alcohol 52 because I thought it would be cool to be able to play the old X-wing games on my cab (with N-64 controllers for the analog stick).
Anyway, I used the above software to copy the disc and mount it to a virtual drive.
The original X-wing works great but X-wing Versus Tie Fighter always "realizes" that the CD is not in the drive and asks for it.
What am I doing wrong?
MaximRecoil
Re: Virtual drive not fooling XvT
« Reply #1 on: August 30, 2005, 03:25:22 pm »
Sounds like you need a "no cd crack" or something along those lines. I don't know much about it; it is a form of copyright protection that prevents copies of original games from running. Assuming you own the original game and just want a more convenient way to run it; try making the image with a tool designed for such things like Alcohol 120% or CloneCD, then mount the image in Daemon tools or whatever and give it a try. There is a ton of information (including message boards such as http://club.cdfreaks.com/forumdisplay.php?f=80) on the net about getting around the various forms of copy protection on game discs in order to make backups. You could start with a few Google searches I suppose.
JCKnife
« Reply #2 on: August 31, 2005, 04:42:51 pm »
This is exactly what I did. It's not working.
Patches? Settings? Where am I going wrong?
MaximRecoil
« Reply #3 on: August 31, 2005, 08:38:09 pm »
Well, a "no cd crack" is one possible option as well as different copying/burning techniques for that particular game or form of copyright protection on your game; being another option. You will have to research it. I would check out forums and do some Google searches like "X-wing Versus Tie Fighter" "no cd crack"; or "Backup X-wing Versus Tie Fighter"; something along those lines.
« Last Edit: August 31, 2005, 08:42:39 pm by maxim_recoil »
JCKnife
« Reply #4 on: September 05, 2005, 09:49:23 am »
This Googling brings up a lot of scary, pop-up infested BS. Anyone have a reliable source for no-cd patches?
madmagician
  • Last login:July 27, 2007, 11:53:37 pm
« Reply #5 on: September 05, 2005, 06:29:34 pm »
Not sure about XvT (dang I need to dust off those discs)  But alot of older games greated an *.ini file with the CD drive letter.  You may need to edit that INI.  I have done this on several games including Riven, MYST 3 and others.
Appearing and Disappearing from Forums and BBS's for over 15 years
-MadMagician
beek
  • Last login:March 22, 2020, 11:25:49 am
« Reply #6 on: September 06, 2005, 01:15:17 pm »
try www.gamecopyworld.com
Havok
  • Trade Count: (+17)
« Reply #7 on: September 07, 2005, 04:54:46 pm »
I second that site - definitely safe to visit...
Ed_McCarron
« Reply #8 on: September 07, 2005, 10:50:02 pm »
In Daemon tools, check out the different security options.  Diablo II, for example, needs 'securom' turned on in the options menu.
