Author Topic: Stretching - mamewah vs command line  (Read 1482 times)
cerebus
  • Last login:November 01, 2005, 10:51:28 pm
« on: August 23, 2005, 10:05:12 am »
Ok, on certain games I'm getting poor performance when launching from mamewah, but different results when I run mamepp.exe from the command line.
My mamepp.ini has hwstretch 1; resolution 640x480.
If I launch super gem fighter from the command line runs at 55 fps but is _not_ fullscreen.
When I launch it from mamewah it's fullscreen but chugs...
Interestingly, a mamepp -showconfig displays up the settings in the ini file o.k. so I can only assume mame is failing on the hwstretch. I'd hazard a guess that my crappy onboard video doesn't support hwstretching, but before I go out and buy a new one can anyone confirm this is what is happening?
Re: Stretching - mamewah vs command line
« Reply #1 on: August 23, 2005, 10:40:52 am »
Try using mame.ini instead of mamepp.ini.  I recall some time ago we found out that MAME had a bug/feature(!) which essentially meant mame.ini would be used instead of mameexename.ini.
