Author Topic: problems: switched yoke wires in u3100  (Read 1756 times)
juggle50
  • Last login:May 14, 2026, 01:13:56 am
  • Your either on the bus or off the bus
« on: August 23, 2005, 03:53:25 am »
I have a coktail cab and I read all the posts regarding switching the red/blue and yellow/green in order to get the screen to flip.  I did it and for the most part it went well.  The screen flipped but now I can't get some programs to work.  Mame is fine but daphne's video is all screwy, Mess won't load, and in Pinmame I can't get the tables to come up properly.  I am also using pivot pro at 0 degrees.
Also, there is a very slight discoloration to the left of the screen.  I'ver heard adjusting some sort of magnets will take care of that.  Does anyone know what magnets and how exactly to do it.  Thank you.
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
Re: problems: switched yoke wires in u3100
« Reply #1 on: August 23, 2005, 07:23:27 am »
Pivot pro screws up alot of programs.
What video card are you using?
Later,
dabone
dabone
  • Time to work...
« Reply #2 on: August 23, 2005, 09:37:40 am »
Ok, went and found the name of a program taht automatically rotates using your
native drivers.
http://www.entechtaiwan.net/util/irotate.shtm
See if this helps.
Later,
dabone
