Author Topic: Convergence Tips??  (Read 1816 times)
lettuce
  • Make It So!
Convergence Tips??
« on: August 20, 2005, 05:02:57 am »
I have a WG K7000 25" monitor, and am using the Nokia Screen test program to sort out the convergence. I am having trouble getting all the lines to line up correctly across the whole of the screen, i would get 80% of the screen lined up, but then there would be an area that wouldnt be lined up at all, and when i try and line this area up it throws the other 80% screen out!
I have noticed that you can change the colours round when press the mouse button, do i need to line up one set of colours correctly then press the mouse button to change the colours around then setup the lines again for them colours, and so on?? If anybody has some helpful tips or knows of a good guide then i would be greatful!?
Ken Layton
  • Guru
  • Technician
Re: Convergence Tips??
« Reply #1 on: August 20, 2005, 10:15:09 am »
The k7000 service manual which you can download from several sites like atarijeff.com shows which magnetic rings to rotate for which colors.
The best pattern you can use for convergence is the "white crosshatch" pattern. To fine tune the edges you tilt the yoke slightly one way or the other (up-down, side-to-side, etc.) with those rubber wedges. Yoke alignment affects the edges of the tube and overall red-green-blue purity.
lettuce
  • Make It So!
« Reply #2 on: August 20, 2005, 12:38:28 pm »
Yeah i have the manual, where can i get the white crosshatch pattern from?
lettuce
  • Make It So!
« Reply #3 on: August 20, 2005, 02:05:46 pm »
can you think of game that has one in?
Ken Layton
  • Guru
  • Technician
« Reply #4 on: August 20, 2005, 06:43:37 pm »
Street Fighter 2, Stargate, and Defender have test modes with great video test patterns that include white crosshatch.
lettuce
  • Make It So!
« Reply #5 on: August 20, 2005, 08:49:32 pm »
Ok thanks, think ive got it pritty much sorted now, and dont think im going to get it any better, im guessing its quite impossible to get it 100% correct on these older monitors!?
