Author Topic: Mamewah and Joystick  (Read 4935 times)
Mark70
  • Last login:August 19, 2011, 11:22:49 pm
« on: August 19, 2005, 11:57:45 pm »
Hi everyone.
I'm running mamewah 1.61 on windows xp home and using a logitech wingman digital extreme joystick.
I've used the joystick successfully with mame launched from dos, with turbomame front end, with mame32 front end, but I am having a little trouble with mamwah.
I can use the joystick to select games from the mamewah screen, but once the game is launched it no longer responds to the joystick.
I expect my problem is coming from my lack of understanding of the ini setup. I had trouble, but eventually got a custom layout, so I'm sure I can get this, I just need a nudge in the right direction.
... arcade builders could someday rule the world...currency would be reduced to quarters only, and wars would be settled
NoOne=NBA=
Re: Mamewah and Joystick
« Reply #1 on: August 20, 2005, 12:12:43 am »
There's a variable called "joystick" in the "Input Device Options" section of the mame.ini file.
Set it to 1, and you should be set.
Mark70
« Reply #2 on: August 21, 2005, 08:16:24 pm »
Hm, the trick seems to have been to go to the mame.ini file that's in the mamewah directory and add the -joystick switch to the commanline format.
« Reply #3 on: August 22, 2005, 05:08:57 am »
It would be easier to modify your \mame\mame.ini file accordingly.  Note this is a mame config issue and not mamewah...
Mark70
« Reply #4 on: August 22, 2005, 09:24:35 am »
Actually the .99 version of mame that I'm running doesn't have a miscellaneous options section in the mame.ini file.  It's set up with the ctrlr folder.  I looked in every ini file I could find and didn't see any joystick feilds.  What I needed to do was learn how this controller folder setup works.  The mame ini file I have in the mame directory only has a few path names in it.
« Reply #5 on: August 22, 2005, 11:08:05 am »
That's interesting.  I haven't upgraded to .99 yet...
2600
« Reply #6 on: August 22, 2005, 11:29:32 am »
Mark,
What version of MAME are you using? i.e. MAME, MAME32, MAMEPP
If you backup your ini file in the MAME directory, and run "mame -cc" a new ini file will be created.
There is a joystick option about half way down under
***********input device options*****************
