Author Topic: Mounting a Happs 3" Trackball Question  (Read 3229 times)
lordsub
  • Last login:March 24, 2003, 02:36:52 am
  • I want a wabinet!
« on: January 02, 2003, 11:40:50 pm »
Im about to place my order for a Happs 3" Trackball.  I plan on mounting it on a 5/8 MDF board + 1/8 lexan control panel.  Do i need to get the trackball mounting kit also?  or is it not necessary? I dont want a high ball.
This is the kit: http://www.happcontrols.com/trackballs/55110100.htm
This is the trackball, blue translucent: http://www.happcontrols.com/trackballs/560100xx.htm
Thanks,
Jeff
ripzone
  • Last login:February 23, 2006, 02:28:01 pm
  • Pac-Mini coming soon...
    • RiP's M.A.M.E. Arcade Cabinet
Re:Mounting a Happs 3" Trackball Question
« Reply #1 on: January 03, 2003, 09:08:45 am »
Yes you need to get the kit!  ;D ;D ;D
dag2000
  • Last login:May 21, 2020, 12:27:05 pm
  • One piece at a time.
« Reply #2 on: January 03, 2003, 02:18:32 pm »
get the kit from Bob Roberts!
wwwtherealbobroberts.com
Smittydc
  • Last login:October 05, 2008, 12:48:10 am
  • because its fun!
« Reply #3 on: January 03, 2003, 03:30:49 pm »
The kit is very helpful.
I routed out a hole in the top of the MDF for the mount so that the artwork and lexan were all flush -- other people have put the mounting kit on top of the lexan.
There are a bunch of threads on here about different trackball mounting techniques -- they should pop up in a search.
Build a man a fire, he's warm for a night.  Set a man on fire, he's warm the rest of his life.
lordsub
  • I want a wabinet!
« Reply #4 on: January 03, 2003, 10:19:50 pm »
Thanks everyone.  I went ahead and ordered the kit with the clear cover.  Id like to make it flush, i hope i can do so.  Thanks
marcopolo
  • Last login:September 28, 2011, 02:11:53 am
  • Life's a ---smurfette---
« Reply #5 on: January 05, 2003, 01:33:12 am »
I bought the 3" high lip (Golden Tee) ball from Happs (not the high ball).  I routed out 1/16" from the top of the CP and mounted the ball using the Clear Zinc mounting kit.  At that point the trackball housing was approx 1/8" above the zinc mounting kit.  Added my overaly, added my lexan, and wa-la, perfectly flush.  Not sure how the standard ball will do height wise, but this was perfect....
