Author Topic: Dust & monitors  (Read 2648 times)
Bones
  • [Moderator]
Dust & monitors
« on: August 17, 2005, 04:17:39 am »
With many cabinet designs having sections at the back open for ventilation, what is the longterm effect of filth around the monitors electronics? Where I am it is very dusty. Would this pose a significant threat to the monitor or its expected lifespan?
My question is directed towards arcade monitors.
Nipedley
  • Last login:October 04, 2024, 12:03:26 am
Re: Dust & monitors
« Reply #1 on: August 17, 2005, 07:41:36 am »
I have a 15 year old 10" monitor that was - and still partially is - completely covered in black .. stuff, maybe its really old dust I dont know? But it still works, just needed a capkit doing and it's still chugging along fine. I cant imagine it'd do a monitor any good, but it doesnt seem to do it any bad either (I'm not a professional so dont take my word for it!)
Ken Layton
  • Guru
  • Technician
Re: Dust & monitors
« Reply #2 on: August 17, 2005, 10:47:00 am »
As with any piece of electronic equipment dust affects proper cooling of the components (especially flyback transformers!). At high voltages dust can actually conduct electricity (especially combined with humidity).
It's up to you to choose whether you'd like to keep your monitor clean and 'healthy' or dirty and ready to croak.
In my opinion a clean monitor is a healthy monitor.
LePic
  • Last login:January 24, 2022, 07:59:00 pm
Re: Dust & monitors
« Reply #3 on: August 18, 2005, 01:18:13 pm »
OK.  Let say I wanted to clean my monitor and remove all the dust.  How do you proceed?  There's a ton of stuff I don't want to touch back there because I don't know enough about it.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
Re: Dust & monitors
« Reply #4 on: August 18, 2005, 02:51:01 pm »
For cleaning dust from electronic components it is common to use canned compressed air... which is readily available at electronics retailers.
Happy Gaming!
2600
Re: Dust & monitors
« Reply #5 on: August 18, 2005, 03:36:35 pm »
Canned air is barely going to clean the dust on top of the crap in some of the monitors I've seen.
RetroACTIVE
  • Gramps
Re: Dust & monitors
« Reply #6 on: August 18, 2005, 05:00:55 pm »
Well.. If you have a ton of goop on the monitor, your right... canned air probably won't do.  However it is fine for maintaining a somewhat clean one.
Besides, if it is filthy dirty then you are probably best to just leave it alone, its old and the dirt has become a part of it...
Happy Gaming!
Ken Layton
  • Guru
  • Technician
Re: Dust & monitors
« Reply #7 on: August 18, 2005, 06:02:23 pm »
Cleaning monitors has been beaten to death. Just search for the threads.
SirPeale
  • Green Mountain Man
Re: Dust & monitors
« Reply #8 on: August 18, 2005, 08:38:04 pm »
Agree with Ken.  Here's a hint: pull the chassis and wash it in the sink!
Bones
  • [Moderator]
Re: Dust & monitors
« Reply #9 on: August 18, 2005, 08:42:26 pm »
It must be a pretty fine line between having enough ventilation to let everything breathe and stay cool, yet not so much ventilation that all the airborne crap gets sucked in and deposited in sensitive places....
SirPeale
Re: Dust & monitors
« Reply #10 on: August 18, 2005, 11:31:53 pm »
Well...no, actually.  You want as much ventilation as possible to cool your components.  You should just remember to clean inside the cabinet on a regular basis, ie every six months or so, depending on how fast it gets dirty inside.
Powers supplies and things with fans should be cleaned *quite* regularly, as the heat buildup will result in premature failure.  Remember...heat is electronic components mortal enemy.  The cooler the components are, the longer they'll last and happier they'll be.
AceTKK
  • Last login:August 20, 2011, 01:14:48 am
Re: Dust & monitors
« Reply #11 on: August 19, 2005, 02:15:52 pm »
you also might want to consider using some kind of filter on the intake of your ventilation/cooling system.  My PC case has a fine mesh filter on the intake fans and it goes a long way towards keeping the inside clean.
I want my own arcade controls!
