Author Topic: Is there any way to block the "known problems" screen  (Read 3199 times)
rlemmon
  • Last login:April 06, 2022, 02:54:46 am
« on: August 17, 2005, 03:18:03 am »
Hi does anyone know of a way to block the known problem screens that pop up with some games ?
Franco
Re: Is there any way to block the "known problems" screen
« Reply #1 on: August 17, 2005, 04:27:18 am »
Im not sure about other mame builds but im pretty sure you can block them if you use BuddaMAME.
elvis
  • Last login:January 13, 2025, 08:48:40 am
  • penguin poker
    • StickFreaks
« Reply #2 on: August 17, 2005, 04:44:19 am »
Outside of using a custom build, the only way to get rid of those is to hunt down the error screen in the source and comment it out yourself.
I've done this in the past.  It's not entirely difficult to comment out a block of code and recompile via the detailed instructions over at mame.net.
Tiger-Heli
    • Tiger-Heli
rlemmon
« Reply #4 on: August 17, 2005, 10:29:48 pm »
thanks for tthe info guys :)
D5A1AC
« Reply #5 on: August 18, 2005, 06:41:12 am »
-skip_disclaimer
Disables the game disclaimer information before the game.
-skip_gameinfo
Disables misc game information before the game.
Is this any help?
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: August 18, 2005, 07:49:23 am »
-skip_disclaimer
-skip_gameinfo
Is this any help?
Nope - he's looking for -skip_warnings from either NoNameMAME or BuddaMAME, but the link I posted has all the details.
D5A1AC
« Reply #7 on: August 18, 2005, 07:58:09 am »
My bad  :(
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: August 19, 2005, 08:10:24 am »
Howard Casto just found that in MAME 0.79 or newer, you can bypass these by adding -ftr 1 after the game name.  I will be updating the link above to reflect this.
rescue161
  • Last login:August 04, 2025, 05:20:11 pm
  • I built my own Cabaret machine!
« Reply #9 on: August 20, 2005, 02:06:01 am »
"Censorship reflects a society's lack of confidence in itself." - Supreme Court Justice Potter Stewart
mccoy178
  • Trade Count: (+9)
  • Last login:August 20, 2026, 01:21:00 pm
  • Go Bucks!
« Reply #10 on: August 20, 2005, 02:41:36 am »
In the mame.ini in the mame folder, the line that says "Frames_To_Run", change the "0" on the right to "1".  Howard Casto is a mad genius.  I don't understand him, nor do I try, but the guy is damn smart.
rescue161
« Reply #11 on: August 20, 2005, 03:04:13 am »
Or if you're not-so-smart like me, you can open up a command prompt at C:\mame and type:
"mame galaga -ftr 1 -cc"
and then it will save it for you.
Once again, thank you!
