Author Topic: Candy cab moving  (Read 2205 times)
quadmasta
  • Last login:May 18, 2022, 03:23:00 pm
    • Approximate Arcades
Candy cab moving
« on: August 15, 2005, 10:17:29 pm »
Does anybody know if a Neo Candy 29 will fit on its back in the rear of an Explorer?
Stingray
Re: Candy cab moving
« Reply #1 on: August 16, 2005, 12:03:05 pm »
A Dynamo cab will. Can you provide dimensions?
-S
DYNAGOD
  • Last login:May 21, 2012, 07:01:55 am
  • sprites taste better than polygons
« Reply #2 on: August 16, 2005, 02:17:00 pm »
the candy cabs are designed to fit thru a house door. i would say yes if its a hatchback.
i just sold my 29" Egret and the buyer picked it up in a suburban type vehicle.
And it s no smaller if not bigger than a candy 29
Enjoying the fruits of technological obsolescence one game at a time...
grueinthebox
  • Last login:February 07, 2014, 12:37:03 pm
  • Feed your head.
    • red42.com
« Reply #3 on: August 16, 2005, 02:21:14 pm »
If that's a full size Dynamo, then the candy cab should have no problems.  From memory, the Neo Candy 29 would be ~53" tall, ~26" wide, and ~30-36" deep...  I'm at work, so I can't measure.  Definitely smaller than a normal full size cab, though.
EDIT: home, found some dimensions I'd taken for someone else at one point...  56" high, 28" wide, 36" deep overall.
« Last Edit: August 16, 2005, 04:46:12 pm by grueinthebox »
"All right. It's Saturday night. I've got no date, a two liter bottle of Shasta, and my all Rush mix tape. Let's rock!"
Stingray
« Reply #4 on: August 16, 2005, 03:05:07 pm »
Yep, full sized Dynamo. The hatchback wouldn't close all the way, it lacked maybe two inches of clearance to latch. Had to tie it down.
-S
kenzo42
  • Last login:November 23, 2024, 01:11:32 pm
« Reply #5 on: August 16, 2005, 11:45:48 pm »
i had to take the door off its hinges to get my astro city to fit. needed another 1/2 inch. pita.
the door never quite closed the same again, even though everything seemed to line up.
kenzo.
muell67
« Reply #6 on: August 17, 2005, 07:23:08 am »
Mine fit in the back of my 96 tahoe with plenty of room to spare. A explorer should be no problem.
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
« Reply #7 on: August 22, 2005, 04:53:26 pm »
I hope you got a good price for that cab!
I have hauled Astro and Windy cabs in the back of an Explorer no problem (you have to put it in on its side).
dogg0
  • Last login:December 14, 2014, 01:18:29 pm
  • ALL? no ALL!!!
« Reply #8 on: August 23, 2005, 09:17:21 am »
[insert just drop the cab off at my place joke here]
thou shalt not supress flatulence
-the bassmaster general
