Author Topic: PC causing static on TV screen  (Read 1609 times)
ratabase1
  • Last login:August 24, 2020, 09:51:51 pm
« on: August 15, 2005, 12:30:04 pm »
 ???Has anybody else experienced this?
tristan
  • Last login:October 07, 2022, 05:37:32 pm
  • I have no idea what's going on
    • Nothing
Re: PC causing static on TV screen
« Reply #1 on: August 15, 2005, 01:04:03 pm »
Are they plugged into the same outlet? If so, try a good/better power strip, or put them on different outlets. You could also try a power filter. I suppose it could be RF interference as well, but generally when I've seen this, it's coming over the power line.
ratabase1
« Reply #2 on: August 16, 2005, 10:21:11 pm »
They were both plugged into the same power strip to begin with.
Silver
  • Last login:December 27, 2025, 08:11:46 am
  • Cunning like the Fox.
    • Mods'n'Mods
« Reply #3 on: August 17, 2005, 11:27:42 am »
Well I would try some more shielding. Get an old computer case or sheet of metal and see if placing it inbetween the pc/tc helps.
Also pay close attention to the cables that feed your tv - its more likely the interference is being picked up in the signal cables than the tv itself. Make sure those cables don't run near the pc or any of the pc's leads.
ratabase1
« Reply #4 on: August 18, 2005, 09:20:28 pm »
Thanks for the input tristan and silver.  I have found the problem.  It was my power supply in the computer.  I switched it out, and the interference with the TV's went away.  I'm glad that's all it was.
