Author Topic: where can one buy controller ports?  (Read 2839 times)
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« on: August 14, 2005, 04:05:55 pm »
where can you buy buy controller ports for the NES, SNES, master system, megadrive, Saturn, playstation (1&2 if there is a difference), Xbox and dreamcast Dreamcast? not nessicerilly in the same place of course.  preferably in the uk but im sure it wouldnt cost too much to import a few ports!
note: i know that atleast the megadrive uses a rather standard 9 pin D connector, but standard types of them with a metal hood damage the plug on the controller.
Tahnok
  • Last login:May 28, 2008, 06:09:25 am
  • Error recording error codes. Remaining errors lost
    • Table Arcades
Re: where can one buy controller ports?
« Reply #1 on: August 14, 2005, 04:23:06 pm »
If you want the mounted type like on the actual systems, you will need to buy old systems. If you just want the connector and don't care, buy extension cables.
Note: Out of town with limited internet access 2-28-08 through 3-16-08
Bartop/Countertop Cabinet Kits For Sale
ultramagnus
« Reply #2 on: August 15, 2005, 03:41:24 pm »
not too hard to mount extension cables, but i was wondering if there was anything easier or cheaper (especiall for old consoles)
Setabs
  • Last login:March 07, 2015, 03:03:23 pm
  • 100% MAME compatible.
    • Another Useless Webpage
« Reply #3 on: August 15, 2005, 05:13:17 pm »
I would just find a broken console and use that.
Adeptus
  • Last login:May 31, 2006, 11:25:07 pm
  • Putting the 'Mad' back in (computer) science
« Reply #4 on: August 16, 2005, 10:59:49 pm »
Unless you can find some console repair place that will sell you their spare parts (probably at more cost than your other options...) ::)
1. Extension cords
2. Dead consoles
3. Multitaps (for NES/SNES/PS1+2)
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
« Reply #5 on: August 21, 2005, 11:14:17 am »
Check yard sales.  I have already bought two consoles like that.
I got a NES console for .50 cents.  No power or controllers though but hey I can use it for the parts.  Also bought a genesis unit (she said they were having problems with it) along with some games and 6 button controllers for $1.
It might pain me to hack up a working console.. but if I know it is damaged it's not too bad hehe.  Also for some controllers, like genesis/Atari, they use a serial compatible port so you can use a PC serial header.
The extension cable might work out well also.  You could mount just the connector part on your cab and have the rest of the cable inside your cab and already hacked how you need it.  May not be exactly the same as an original connector but could be close.
Adeptus
« Reply #6 on: August 21, 2005, 07:44:49 pm »
Oh yeah... you mentioned not wanting to use a 9-pin with a metal hood.
I have seen ones that attach to ribbon cables, that are all plastic. Check your local electronics stores.
(I wouldn't worry, many systems used metal anyway - ie C64, Amiga, Atari ST?...)
ultramagnus
« Reply #7 on: August 22, 2005, 04:22:22 pm »
hmm, ok, thanks, i will look into that.
i have tried using metal hood style plugs, they scrape corners off the plastic connector if your not incredibly carefull, perhaps if i file the sharp parts down? hmm
