Author Topic: Does anyone manufacture "brown" pushbuttons?  (Read 3155 times)
motorfish
  • Last login:September 30, 2009, 03:35:08 am
« on: August 14, 2005, 02:04:58 pm »
I've been looking all around, and I haven't found an manufacturer that makes brown colored arcade pushbuttons. Does anyone here have a possible resource for these, or am I simply out of luck?
- Dan
Have you paid your dues Jack?......Yessir, the check is in the mail!
NoOne=NBA=
Re: Does anyone manufacture "brown" pushbuttons?
« Reply #1 on: August 14, 2005, 02:24:02 pm »
I don't remember ever seeing any.
You might be able to have a custom run made, but the price would be prohibitive, and you probably have to buy ALOT of them.
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
« Reply #2 on: August 14, 2005, 02:50:14 pm »
I've never seen or heard of brown pushbuttons myself.
Short of having a run made like NoOne suggested, I think the only way you'll see a brown button is if you paint it yourself.   Is there a brown Krylon Fusion paint?  That's meant for plastic specifically..... I know people have painted buttons before with less than perfect results, but I think it's your only bet.
first off your and idiot
versapak
  • Somewhere between a block of wood and a monkey
  • Last login:Yesterday at 08:02:25 am
  • I am t3h GAY!!!
« Reply #3 on: August 14, 2005, 03:35:09 pm »
You could try Rit fabric dye on white buttons.
It does indeed dye plastic, but I have heard that getting the color you are looking for can be a challenge.
ultramagnus
  • Last login:September 09, 2005, 02:10:45 am
« Reply #4 on: August 14, 2005, 03:48:59 pm »
the only place i have seen them is arcades, ironically.
having an intrest in minature (28mm scale to be precise) moddeling i can tell you it wouldnt be incredibly hard (and alot cheaper than having a run made by a company) to make a mould of the parts of a pushbutton you want brown and then casting them out of resin that has had a brown colour addadative added to it.
apart from that well, you could try painting or dying white ones, but that would probabally yeild dubious results
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
« Reply #5 on: August 14, 2005, 03:56:30 pm »
What about the "brown note". Has anyone found that yet?  ;D ;)
Signature tags are dumb.
ultramagnus
« Reply #6 on: August 14, 2005, 04:08:04 pm »
the brown note is a stupid urban myth that doesnt exist....
Kremmit
  • - AHOTW -
  • Who the heck is that?
« Reply #7 on: August 14, 2005, 04:57:39 pm »
Tom at Specialty Plastics makes Nintendo-sized buttons, which are just barely smaller than standard arcade buttons.  He might be able to do a set of those in brown for you.
http://members.aol.com/specialtyplastic/index.htm
quarterback
« Reply #8 on: August 14, 2005, 09:20:43 pm »
Kelsey painted the joystick he used on his Galaga bartop and it looks great from what I can tell.
-- Chad Tower
versapak
  • I am t3h GAY!!!
« Reply #9 on: August 14, 2005, 09:24:32 pm »
I can't imagine painting works out anywhere near as well on a button as it would on a stick.
The button has to slide smoothly, and I figure painting it would stop that. It would make the button slightly larger, so it wouldn't fit in as nice into its chamber, plus the paint to paint rubbing would cause sticking issues.
danny_galaga
  • Last login:Today at 04:29:51 am
    • dans cocktail lounge
« Reply #10 on: August 15, 2005, 02:29:17 am »
yeah, casting is the go i reckon. theres a few members here who cast parts for models, etc. and the results are great. buttons would be a cinch...
rdagger
« Reply #11 on: August 15, 2005, 02:34:38 am »
You could get clear buttons and paint the inside brown.
« Reply #12 on: August 15, 2005, 06:12:19 am »
You could get clear buttons and paint the inside brown.  This would give a clean finish and prevent the paint from rubbing off.  You could also illuminate clear buttons to brown.  I think a red and a green LED would give you brown.  The buttons on my cab rotate colors including brown, but I'm using RGB LED's with a custom board.
That's a good idea!   :o
