Author Topic: Question on monitor and video card used in 'Project Arcade'  (Read 7195 times)
TheBrokentoken
  • Last login:December 13, 2009, 09:19:37 am
  • Being a noob is awesome! (not)
    • Brokentoken.com
« on: August 14, 2005, 10:06:52 am »
First off, this is my first post on BYOAC.  This looks to be a great place to hang out.  Secondly, my compliments on the book.  I'm well over 1/2 of the way through it, and even though I've not started building yet, the time the book will save is enormous.  Well worth the $$.
I notice that in chapter 12 Saint mentions that he used a Happ Controls Vision-Pro SVGA 27" monitor in the cabinet.  I've looked at both the Wells Gardner D9200 and the Betson, but is this a 'better' monitor to use than either of those?  Both the Betson and the WGD9200 seem to have their share of problems.
Also - what video card was used on Project Arcade?  I don't see it mentioned anywhere in the book.  I'm curious if the ArcadeVGA was used or if a 'normal' VGA card was used.
- Whitney Roberts
http://www.brokentoken.com
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:June 21, 2026, 12:29:22 am
Re: Question on monitor and video card used in 'Project Arcade'
« Reply #1 on: August 14, 2005, 11:17:38 am »
I've had zero problems with my monitor so far, but have no experience with the other monitors mentioned. I'm using a standard video card (in fact, currently in Project Arcade is an e-machines computer with on-board video).
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
TheBrokentoken
    • Brokentoken.com
« Reply #2 on: August 14, 2005, 11:29:25 am »
OK, thanks for the info.
After doing a good bit of reading, I'm finding out that the 'true' arcade (WG D9200 and the Betson Imperial ) monitors are able to do a 15.7kHZ mode as well as a 31kHZ mode.  The Happ monitor lists supporting a 30-40kHZ mode and not the 15.7kHz that the ArcadeVGA card puts out to support the native resolution of some of the older games (Pacman/Ms.Pacman/Donkey Kong/etc. vintage)
I guess my real question is this - Does the Happ Controls monitor do a good job of making the (older) 15.7kHZ games look authentic?  What does a game like Donkey Kong look like on it?
I'm all about the Happ Monitor if it'll give me good results.  The color pictures on the CD are great, but it'd help a lot to see some actual gameplay screen shots of the Happ Controls monitor next to a PC monitor.  Would that be possible for you to do?
Also - thanks for confirming the video card information.  In all the reading I'm doing, there doesn't seem to be a clear deliniation on when the ArcadeVGA card is necessary and when it's not.  Thanks for the clarification!
- Whitney Roberts
squirrellydw
  • Last login:April 12, 2021, 11:30:22 am
« Reply #3 on: December 18, 2005, 11:28:12 pm »
can anyone answer this??
I b**ch. People listen!!
« Reply #4 on: February 20, 2006, 09:20:53 am »
To me....
It looks fine on a computer monitor or an arcade. I just don't see a big difference.
AtomSmasher
    • Atomic-Train
« Reply #5 on: February 20, 2006, 11:30:05 am »
Probably best to ask this question in the monitor section, you'll likely get more results there.
