Author Topic: I-Pac / Mini-Pac Question  (Read 2966 times)
MameJunkie
  • Last login:March 19, 2009, 08:23:45 pm
  • Eeeeeeeevil
« on: August 13, 2005, 01:50:58 pm »
I have everything hooked up and all the switches seems to work.
BUT whatever switch I program to be the ESC, it will not function.
In the configuration program, hitting the ESC from the keyboard shows up but the button I programmed will not.  If I reprogram that button to something else, it will work; that at least tells me its not a hardware problem.
Another question on the 'shift' key, my understanding is that when the 'shift' key is pressed + another key, the 'shift' function for that switch/button (ie another keycode) will be generated.
True?  If so, that also doesnt seem to work. ???
Thanks for any clue on what I have missed.
Teamwork - A group of people running around doing what I say.
Tiger-Heli
    • Tiger-Heli
Re: I-Pac / Mini-Pac Question
« Reply #1 on: August 13, 2005, 02:14:53 pm »
Odd, programming seems to be working, since you can re-program away from it and get it working.
Are you using the correct sofware, which for the minipac would be here?:  http://www.ultimarc.com/winipac.html
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #2 on: August 13, 2005, 03:19:37 pm »
Are the jumpers set to MAME?
NO MORE!!
MameJunkie
  • Eeeeeeeevil
« Reply #3 on: August 14, 2005, 08:43:09 pm »
The jumper is default (MAME).
The ESC part still doesn't work.  I'm going to try and  the ALT setting and reprogram all the swithes I need manually.
MameJunkie
  • Eeeeeeeevil
« Reply #4 on: August 14, 2005, 09:05:32 pm »
Still doesn't work.
Is what I'm doing to reset the switch keycode correct?
If I wanted P2-SW8 to be ESC when pressed,
click on the 'P2-SW8' in the configuration program and
then press 'ESC' when asked what key to assign to it.
Correct?
Rook3
  • Last login:August 07, 2025, 01:40:55 am
  • Greetings Starfighter! You have been recruited...
    • Rook's Castle.com
« Reply #5 on: August 14, 2005, 09:31:24 pm »
Isn't the default escape key sequence done by holding the Player 1 & 2 start buttons?
Russ
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: August 15, 2005, 06:34:03 am »
Still doesn't work.
Correct?
Sounds right.
Can you confirm you have the correct software.  The Minipac doesn't work with the Interactive Panel Designer, last I heard.
MameJunkie
  • Eeeeeeeevil
« Reply #7 on: August 15, 2005, 12:14:46 pm »
Sounds right.
Tiger-Heli
    • Tiger-Heli
« Reply #8 on: August 15, 2005, 12:22:16 pm »
See my post above, you should have the software with the purple buttons.
MameJunkie
  • Eeeeeeeevil
« Reply #9 on: August 15, 2005, 01:20:45 pm »
Yea thats not the version I have.  Its the new one with the panel designer.
I'll try and download the old version and give it a try tonight.
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
« Reply #10 on: August 16, 2005, 06:31:23 am »
Non-working shift functions indicate one or more stuck buttons, or mis-wired.
There are 2 versions of the board. The one with jumpers is the older type and needs the older WinIPAC program to re-program it.
The later board has no jumpers, and has a self-test LED which can be used to easily locate any stuck connections. This uses the later program, above.
But, ESC (hold start1 and press start2) should work without re-programming so a stuck connection seems to be the problem.
Andy
Tiger-Heli
    • Tiger-Heli
« Reply #11 on: August 16, 2005, 07:38:17 am »
Andy, any idea when this change was implemented?  I need to update my infamous chart: http://www.mameworld.net/tigerheli/encoder/main.htm#I-PAC_Software_Compatibility (or I can just say "with Jumpers" and "without Jumpers"
MameJunkie
  • Eeeeeeeevil
« Reply #12 on: August 16, 2005, 12:21:47 pm »
I tried the older version of the software last night and it works ALOT better. :)
On question though...do I need a USB cable in order to "Program" it?
It times out when I try to do it in the software.
BTW: I got the MiniPac awhile ago 9-10 months.  Just got around to doing my cab.  Will be posting early pics of it later.
