Author Topic: Mounting the Happ Super Topfire (the one with the bright red button on top)  (Read 1521 times)
AndyP
  • Last login:January 01, 2003, 06:22:30 pm
Can anyone explain how I get the joystick separated from the base?  It's not like the competitions, so I'm a little bit confused.  I was thinking I'd need to take off the plunger from the bottome of the stick, but it doesn't seem to want to come out, and I don't want to break it.
Help?
Silverwind
  • Last login:September 26, 2022, 12:49:09 am
I only have happ super..  and not the top button..
have you looked at the diagram yet?  It may be able to help..
http://www.happcontrols.com/joysticks/50800010x.htm
eightbit
  • My cab is never done...
It looks to me like most other joysticks other than the actuator and the switch for the top bottom. You pull that c-clip at the bottom and the joystick handle should slide up and out.
