Author Topic: Need to take my first Step and get a monitor!  (Read 1693 times)
miles2912
« on: August 12, 2005, 02:00:45 am »
Bought a used stripped cab and need to get a monitor.
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
Re: Need to take my first Step and get a monitor!
« Reply #1 on: August 12, 2005, 01:24:45 pm »
Who manufactured the cab? If you can find a mfg label or serial, we might be able to tell you what came with it originaly.
Signature tags are dumb.
miles2912
« Reply #2 on: August 12, 2005, 06:32:41 pm »
It was Boot Cammp made by Konami.   I see a Konami sticker on the back but no other markings.
Miles
eraserhead
  • Last login:August 18, 2005, 10:18:37 am
« Reply #3 on: August 17, 2005, 09:05:57 pm »
the only 25 that comes to mind that'll fit in your space (with a little modification) is the hantarex mtc 25 ev/2.  to make it work - you would have to bend the side and top mount ears back - and make a shelf that the monitor sits on (there are bottom mounting slits
but.....
if you live in the states - this badboy will have to be shipped from sambers in italy.  the journey is ROUGH on the monitor (and their packing really isn't suitable).  mine got chipped and had a bent frame when it arrived.
heaven forbid you ever have to make a claim with UPS Italy - took me over 5 months to get my money....
every other 25 i've ever seen is larger - and most likely won't fit in your cab.  i'd consider something smaller - although i do appreciate the need to have the largest monitor possible :)
