Author Topic: MEKAW .71 and Mamewah error help needed  (Read 2656 times)
killbill
  • Last login:June 10, 2026, 07:51:30 pm
  • When I die, I want to go to arcade heaven!
« on: August 11, 2005, 07:12:02 pm »
Hi,
I noticed on this .71 version that there is a new set up type window that appears for a moment before the emulator gui comes up.
« Last Edit: August 16, 2005, 02:17:27 pm by killbill »
2600
Re: MEKAW .71 hack question
« Reply #1 on: August 11, 2005, 07:26:38 pm »
Won't answer your question, but have your tried Kega Fusion.
Emulates nearly all the Sega consoles pre-Saturn and is supposed to be really good.
killbill
« Reply #2 on: August 11, 2005, 10:03:30 pm »
I'll check it out.  Thanks 2600
beek
  • Last login:March 22, 2020, 11:25:49 am
« Reply #3 on: August 11, 2005, 10:13:48 pm »
I agree.
I had it just running the mastersystem but tonight tried it on Genesis and 32x......works great.
stuzza
  • Last login:May 13, 2025, 09:19:19 pm
    • ScreenshotArchive
« Reply #4 on: August 12, 2005, 02:30:54 am »
The latest MekaW (including the one on Screenshotarchive) don't require a hack at all for escape.
killbill
« Reply #5 on: August 15, 2005, 01:40:13 pm »
Thanks, Stuzza!
I used the Meka Configurator, and set it to cabinet mode.
When I try to run a game from Mamewah, this error window pops up:
Meka 0.71
(c) Omar Cornut (Bock) and contributors
Loading MEKA.MSG (messages)..
Parameter "-verifyroms" is invalid!n--
Syntax: MEKAW [rom] [options] ...
Where [rom] is a valid rom image to load. Available options are:
  -HELP -?         : Display command line help
  -SETUP           : Start with the setup screen
  -EURO -US        : Emulate an European/US system for this session
  -JAP -JP -JPN    : Emulate a Japanese system for this session
  -DEBUG           : Enable debugging features
  -LOAD <n>        : Load savestate <n> on startup
  -LOG <file>      : Log message to file <file> (appending it)
  -NOELEPHANT      : Just what it says
How can I get rid of this?  Help?!
« Last Edit: August 15, 2005, 09:45:46 pm by killbill »
killbill
Re: MEKAW .71 and Mamewah error help needed
« Reply #6 on: September 30, 2005, 07:16:30 pm »
Never got an answer on this and it is still happening, no matter what I try.
Anyone experience this?
Thanks.
2600
« Reply #7 on: September 30, 2005, 08:42:53 pm »
I believe you have MAMEWAH setup with ... crap forget what it's called.....  the list generation method in your mekaw.ini file in MAMEWAH.   You have it set up for MAME that's why it's verifying roms.
If you can't find it, I'll have to look it up as I'm really tired.  If not, I think I've said enough so Minwah or Jcrouse will see what I mean.
killbill
« Reply #8 on: September 30, 2005, 10:23:30 pm »
Thanks 2600.
I think you're right.
I'll check into it.
jcrouse
    • CPViewer
« Reply #9 on: October 01, 2005, 11:43:54 pm »
I agree. You need to use a list generation methiod of "rom_folder".
John
