Author Topic: Hooking DC pads up to my CP  (Read 2332 times)
DreamWeb
  • Last login:July 25, 2020, 08:36:59 pm
« on: August 08, 2005, 11:59:01 pm »
Ok guys..  I think I've got the hang of this now.
I've got too many buttons and controls on my CP to just use a single DB25, so I have to use two.
My question is...  Can I use the ground coming out of the Keywiz hooked up to both DB25-1 and DB25-2 ?  Will this work?
I've thrown up a very nice picture to demonstrate my proposed setup.  Let me know if you think this'll work ok?
Thanks guys!
d.
DreamWeb
Re: Hooking DC pads up to my CP
« Reply #1 on: August 09, 2005, 12:00:17 am »
Please pay particular attention to how I really 'captured' the likeness of the dreamcast pads.
yes.. I thought you'd like that.
d.
Goz
  • KOTA
« Reply #2 on: August 09, 2005, 12:08:18 am »
Unsure how that setup would work with hacked pads however in theory if you had a shared ground you may run into issues with needing both devices being active for it to work.
Another solution would be if you had a X-arcade BYOA kit it natively connects to a PC via serial to USB and if you were to use it for a Dreamcast its a simple adapter. I wired mine up today with a DB25 (using serial to DB25 adapters) data switch and have Dreamcast, Xbox, Gamecube and PC all selectible using a switch box. No unplugging, etc... No worrying about grounds, etc.. worth a thought if you arent too far into it.
-Goz
DreamWeb
« Reply #3 on: August 09, 2005, 12:12:57 am »
I've already got my CP up and running.  And it's not an x-arcade unit.
Ugh.. if this doesn't work, I really don't know what will.  That ground is really killing me.
Any suggestions?
d.
Goz
  • KOTA
« Reply #4 on: August 09, 2005, 01:01:25 am »
Any suggestions?
d.
I know its not an xarcade unit. I was suggesting that if you continue to have problems its a great way to go. I am of course referring to buying the xarcade encoder and adapter not the horrible panel they make.
-Goz
DreamWeb
« Reply #5 on: August 10, 2005, 12:31:34 am »
Hey folks.  I'm still looking for other suggestions to help me get this going!
Anyone?
d.
RetroACTIVE
  • Last login:January 28, 2024, 04:27:52 pm
  • Gramps
« Reply #6 on: August 10, 2005, 02:05:49 pm »
As far as ground is concerned, you should be fine.  Most if not all logic level ground is the same for the entire system (especially when it comes to USB/PS2).  I would say try it... it certainly won't hurt anything.  Like any other control panel, all the ground leads are typically chained together anyway.
Give it a shot...  I would.
Happy Gaming!
DreamWeb
« Reply #7 on: August 10, 2005, 10:19:53 pm »
I'm willing to give it a go.. but it would require a complete rewiring of my system.  So, I'm hoping to avoid it if it's not going to work.
What I don't understand is...  Is what I'm suggesting completely out of the ordinary?  What do most people do?  I thought I was doing something pretty standard!
d.
Goz
  • KOTA
« Reply #8 on: August 10, 2005, 10:26:45 pm »
d.
The majority of people that I know with Dreamcasts in a cab do not put additional systems or computer with MAME along side the Dreamcast.
With that said you should be able to do what you are suggesting with a DB25 setup.
I've got mine going along side a xbox, ps2, gamecube, and mame but I went the X-arcade BYOA kit and adapters to DB25 w/ a data switch box. So no disconnecting and swapping connectors and it works fine. I have some hacked DC controllers that I can probably use to test this out for you, but likely wouldnt get arround to testing it till Saturday.
-Goz
DreamWeb
« Reply #9 on: August 11, 2005, 12:32:44 am »
Don't spend too much time on it.. but, if you have some extra (time).. please, feel free! :)  I'm a novice with this stuff... so rewiring my cabinet is going to take the better part of an entire weekend! :)
d.
