Author Topic: This has to be th worst burn in on a monitor I've ever seen.....  (Read 1425 times)
M3talhead
  • Last login:October 09, 2020, 07:35:12 pm
  • Dont let Donkey Kong use your toilet.......
Signature tags are dumb.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
Re: This has to be th worst burn in on a monitor I've ever seen.....
« Reply #1 on: August 07, 2005, 03:57:18 pm »
I can't tell from this angle.  what game is that for?   ::)
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
Q*Bert_OP
  • Oh yes, we did!
« Reply #2 on: August 07, 2005, 04:14:33 pm »
Mine is worse...
Tailgunner
« Reply #3 on: August 07, 2005, 08:27:12 pm »
Put a piece of smoked plexi over it and you won't see it. My cocktail cab was a working Capcom Bowling when I bought it, and I had no idea it was originally a Pacman till I removed the monitor and found the maze pattern burned into it.
My Roadblasters monitor has at least as much burn in as that one, I'll take a pic tommorow to post for comparasion.
Q*Bert_OP
  • Oh yes, we did!
« Reply #4 on: August 07, 2005, 08:33:06 pm »
My
Dig Dug
Vulgus
Street Fighter 1
B. Rap Boys cabinet has the worst burn-in I've ever seen :(
Stingray
« Reply #5 on: August 08, 2005, 08:29:42 am »
I had one with Tetris burn in that was that bad or worse at one point. The smoked plexi idea works well. My Space Invaders has pretty bad burn it, but you can't see it with the plexi over it.
-S
« Reply #6 on: August 08, 2005, 10:19:37 am »
Smoked plexi costs more than a used monitor.  Just get a nonworking monitor of the same model # and swap the chassis with your working chassis.
Stingray
« Reply #7 on: August 08, 2005, 11:39:42 am »
I don't know where you're buying plexi, but the piece that goes over my SI monitor cost about $5.
-S
Q*Bert_OP
  • Oh yes, we did!
« Reply #8 on: August 08, 2005, 11:40:53 am »
i buy tempered glass which is veeeerrrrrryyyyyy expensive :-\
