Author Topic: Acknowledging OK without Joystick  (Read 3704 times)
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
« on: August 07, 2005, 01:45:20 am »
If you have a control panel with only a 360 wheel is there any way to bypass or avoid the forced acknowledgement of games with problems by typing "OK" or rocking the stick?
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
AlanS17
    • AlanS17
Re: Acknowledging OK without Joystick
« Reply #1 on: August 07, 2005, 01:48:40 am »
Depending on the version of MAME you disable the OK screen altogether. Check the documentation.
NY_in_TX
  • Last login:February 25, 2017, 11:19:54 am
  • First play's free...next one will cost ya
« Reply #2 on: August 07, 2005, 01:52:06 am »
First I would try going into the config files and set it up to remove the promtps.  that'll work for most games  and most versions of mame.
If the games you have on there still need the "okay".  you could map your shifter to "o" and "k" or if you don't even have that maybe a quick toggle on top of the game or inside the coin door.
toolaa
« Reply #3 on: August 07, 2005, 01:59:27 am »
I have the standard messages disabled however some games have simple video problems or give a "Cocktail Flipping Mode Not Supported" message.  This does not seem to have a setup toggle that I am aware of in MAME v94.
AlanS17
    • AlanS17
« Reply #4 on: August 07, 2005, 02:27:58 am »
No I don't think error messages can be skipped.
I'd recommend mapping "o" and "k" to the shifter as was suggested earlier. Or mount "ok" buttons inside the coin door.
toolaa
« Reply #5 on: August 07, 2005, 12:08:51 pm »
Man I really want to stick with a one button/wheel/pedal configuration.  I sort of like the hidden button in the door idea, but I hate the idea of my kids opening the door.
Anyone ever tried assigning an OK macro to one button?
NY_in_TX
« Reply #6 on: August 07, 2005, 12:30:06 pm »
this is way out of the box..
take two micro switches and put one so it clicks on the pedal when down and the other so it clicks on the up.  map the down one to "o" and the other to "k"
then you can just mash and release the pedal for "ok"
not sure about macros, but as long as it sends the right keystrokes I don't see why it wouldn't work.
depending on what encoder your using you may be able to hook up "o" and "k" to the same switch and see what happens.  it might work, although depending on the order the letters go through go through it might take 2 presses.  "ko" vs "ok"
CJK
  • Last login:February 03, 2024, 03:30:12 am
  • All your ROM are belong to us!
« Reply #7 on: August 07, 2005, 01:11:20 pm »
Would you be willing to recompile the MAME source? Then you could modify the status of the games you're dealing with and eliminate the problem altogether.
-- Chris
Underway: Joey's Arcade
toolaa
« Reply #8 on: August 07, 2005, 01:25:20 pm »
NY and CJK,
Both good ideas.  For the driving cab since there will only be about 40 games I might be willing to re-compile.
AlanS17
    • AlanS17
« Reply #9 on: August 07, 2005, 01:30:40 pm »
-- Chris
Stole the thought out of my head... The mind suckers are coming!!!
CJK
« Reply #10 on: August 07, 2005, 01:43:31 pm »
Dude, I think they might have been there already...
-- Chris
shadowdrak
  • Last login:November 20, 2005, 04:59:54 pm
  • I'm still a llama!
« Reply #11 on: August 07, 2005, 02:48:29 pm »
One problem with using only one button would be that "k" would always be pressed down.  Not really a problem if you never need to do anything besides mame on that setup, but it could cause problems if you have to ever do anything with a keyboard pass-through.  I kind of like the macro idea.
Popcorrin
  • Last login:March 06, 2022, 11:11:43 am
« Reply #12 on: August 07, 2005, 04:25:48 pm »
Since the controls are only going to support about 40 games I am wondering which of those games have the warnings requiring you to press ok?
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #13 on: August 08, 2005, 12:45:01 am »
You have no buttons on the CP? ???  Not even player one start? P1 coin?
'Cause if you have at least two, just remap in mame's gerenal inputs "UI left" and "UI right" to any two buttons.  You see, "wiggle joystick left and right" works because UI left and UI right are mapped to the joystick by defaut.
If you only have one button, try mapping it to both UI left and UI right.  Might work.
Robin
Knowledge is Power
darktemp
  • Last login:July 20, 2006, 11:18:39 pm
  • Rumbler
« Reply #14 on: August 08, 2005, 02:13:40 am »
Download Mametweaks, it allows you to remove all warning messages.
Tiger-Heli
    • Tiger-Heli
« Reply #15 on: August 08, 2005, 07:42:41 am »
Mametweaks requires you to recompile.
General recompiling info here
http://forum.arcadecontrols.com/index.php/topic,36217.msg318959.html#msg318959
BuddaMAME will allow you to skip the screens by setting a flag in the .ini file.
Otherwise, what U_rebel said.
Toonces
  • Last login:March 04, 2024, 11:25:24 pm
« Reply #16 on: August 09, 2005, 02:43:17 am »
Where can mametweaks be found?
Toonces
darktemp
  • Rumbler
toolaa
« Reply #18 on: August 10, 2005, 11:43:59 pm »
I just got back into town.
« Last Edit: August 11, 2005, 01:08:48 am by toolaa »
