Author Topic: Is there a Mamewah tutorial for idiots?  (Read 1883 times)
RichyRich
  • Last login:November 17, 2006, 12:22:40 am
  • If it ain't broke don't try and fix it
« on: August 05, 2005, 09:05:25 am »
Mamewah tutorial for idiots.I have limited computer knowledge so is there any point in trying?I have set up the paths(at least i think I have)in the .ini file and nothing happens.Need help please!!
« Last Edit: August 06, 2005, 08:43:14 am by Peale »
Re: Is there a......
« Reply #1 on: August 05, 2005, 10:50:22 am »
See this page for a few links:
http://mamewah.mameworld.net/help.htm
The only current turorial is in spanish...but JCrouse's example ini files are a great place to start - it helps to have a look at somone else's setup.
If you're not in a hurry, there should be some more docs coming out in the near future.  BTW I am also working on a new version, so it might pay you to wait for that anyway. A Beta of this is available at the ArcadeOS / Mmewah board (see topic in this board for link), and a final version in a couple of weeks - I'm about to go on holiday  8)
RichyRich
« Reply #2 on: August 05, 2005, 03:15:41 pm »
OK Minwah,thanks.I'll wait for the new doc's.
Have anice holiday btw and dont get to drunk. ;)
dabone
  • Last login:July 15, 2025, 08:32:17 pm
  • Time to work...
« Reply #3 on: August 05, 2005, 07:50:49 pm »
Didn't you just get back from a long holiday?
Later,
dabone
Tiger-Heli
    • Tiger-Heli
Re: Is there a Mamewah tutorial for idiots?
« Reply #4 on: August 09, 2005, 05:55:23 pm »
http://www.screenshotarchive.com/mwtutorial.htm This one helped me out ALOT getting it working.  It says it's for the older version, but it still has lots of good hints.
