Author Topic: jamma conversion help  (Read 1172 times)
dan57fina
  • Last login:April 23, 2006, 04:46:22 pm
  • Not bad for 14 years of age....
« on: August 04, 2005, 12:50:46 am »
I'm helping a friend convert a jamma cab into a mame machine....hes looking at the ultimarc j-pac and everything seems great but before he bought it we found this....
IMPORTANT: The J-PAC does not convert or process the video signal in any way except amplify it to the level required by an arcade monitor. The sync frequency jumpers only control the sync-in-range safety check. The PC must be configured to send the correct sync frequency for the monitor unless our ArcadeVGA card is being used.
is there any way for someone to explain to me how to convert that signal withought using the ArcadeVGA card?
any help would be greatly appriciated...
-Dan
AlanS17
    • AlanS17
Re: jamma conversion help
« Reply #1 on: August 04, 2005, 01:08:41 am »
Do research on a program called Power Strip. It's made by a company called EnTech. It'll let you tweak your video card in Windows. It can't unlock hidden capabilities of a card, but it can't make a card exceed its own limitations.
I'll let you do the research on how to use it, though. It's a long drawn out process that I'm too tired to explain. Basically, you tune your video card to output a signal compatible with an arcade monitor. Here's a point in the right direction, though. Arcade monitors are basically TV's without tuners.
krick
  • Gotta have blue hair.
« Reply #2 on: August 04, 2005, 01:17:38 am »
You should check out the EasyMameCab site, especially this page...
http://easymamecab.mameworld.net/html/hardware.htm
Hantarex Polo 15KHz
GroovyMAME 0.197.017h_d3d9ex
Windows 7 Home Premium 64-bit
Intel Core i7-4790K @ 4.8GHz
ASUS Z87M-PLUS Motherboard
