Author Topic: One button to J-PAC & Opti-PAC  (Read 1241 times)
lettuce
  • Make It So!
« on: August 02, 2005, 07:18:07 pm »
I want to have a mouse button wired to one of my service buttons on my CP, how do i got about wiring a J-PAC and Opti-PAC up to use the same button. I did have 2 wires connected to the NO terminal on a button, with 1 wire going to the J-PAC and the other wire going to the Left Button terminal on the Opti-PAC, but this didnt work and caused a few conflicts, so im at a loss. Can anybody help?
Tiger-Heli
    • Tiger-Heli
Re: One button to J-PAC & Opti-PAC
« Reply #1 on: August 03, 2005, 07:00:01 am »
The basic answer is you don't want the same button activating two inputs.
If you are mainly using MAME, you can wire the button to the left Opti-Pac terminal (only) and set MAME up to use the left mouse button for that input.
If you need to use it for other games, I think there is a program called keymouse (?) that will let you send a keystroke when you click the mouse button.
Alternately, I don't know if there's a way to wire the button to the J-PAC and use software to send a mouse-click when the key is pressed, possibly with UltraKeyBoard or AutoHotKey.
lettuce
  • Make It So!
« Reply #2 on: August 03, 2005, 12:52:25 pm »
Well i want the same button to be used as the left mouse button for windows, and then it would be a service button in Mame i.e, pause, menu etc. I was under the impression that it was ok to have the J-PAC and Opti-PAC wired to the same button??
Tiger-Heli
    • Tiger-Heli
« Reply #3 on: August 04, 2005, 08:36:57 am »
I would think you could wire it to both inputs and the only problem would be that pressing the button would send BOTH and keypress and a mouse-click (which could be bad for some games), but I think others have said it causes problems.  At this point, you might E-mail Andy about it and post back what he replies.
