Author Topic: A quick question about wavebirds  (Read 2011 times)
BarontheFirst
  • Last login:April 11, 2023, 07:42:07 pm
  • Locked out of the gameroom again!
« on: July 31, 2005, 02:52:31 pm »
Just curious but does anyone have them hooked up in there cabinet with a gamecube to PC usb adapter? Hidden inside the cab sounds nice and all you got to do is pull a paddle out and it is good to go with no wire. I have a gamecube and three of the paddles judt don't want to buy the adapter without hearing if it worked well for anyone else first. Also if you do have an adapter wich one did you use and were did you buy it? Thanks in advance!
