Author Topic: Vertical Mamewah Set-Up Problems...  (Read 1713 times)
conseit68
  • Will sell anything that isn't nailed down...
  • Last login:February 12, 2020, 10:52:27 pm
  • Back to the Future Cab...In Progress
« on: July 30, 2005, 02:25:16 pm »
Ok I have an older Inspiron 3500 laptop. This laptop has no cd-rom drive. I was finally able to install a fresh copy of win98se. I used a friends USB key (which I don't hanve anymore) to transfer the latest mame, mamewah, mamewah config, and mamewah system programs. I can get mame to work on its own via command prompt. Mamewah will open but with no games shown. Mamewah system tells me that "C:\Mamewah\system>regsvr32.exe paintx.dll is a bad command or file name" while installing and stops. Mamewah config. tells me that "MSCOREE.DLL was not found". HELP
Thanks in advance,
Matt
jcrouse
    • CPViewer
Re: Vertical Mamewah Set-Up Problems...
« Reply #1 on: July 31, 2005, 07:52:10 am »
Go to the official MameWAH forums at http://www.mameworld.info/ubbthreads/postlist.php?Cat=&Board=arcadeospc2jamma and do a search. It's been ask many times and the answer is there.
John
