Author Topic: full screen vs. window?  (Read 2076 times)
SpeedyR
  • Last login:February 19, 2024, 09:13:37 pm
« on: July 30, 2005, 12:05:00 am »
not sure if this is in the right forum or not but i'm having a problem with MAME32. when I run certain games, the screen isn't working right. just mostly black with a few lines of b&w or color depending upon the screen. I can hear the game and it's "working" but I can't see it. If I change the monitor settings to just play in a window rather than full screen, it's fine.
it's just started doing this the past day or so. and only on same games (virtua fighter, tempest, pacman). Others are fine. I ran the same game on my laptop and they work fine. I tried resetting the "factory" settings in mame32 but still no luck. the only thing i've tried that works is to change it to run in a window rather than full screen...
any suggestions on things to try?
BTW- this is just one a standard VGA monitor on a P4 2ghz system if it makes a difference.. not sure what video card I have in it currently.
Jeff
StephenH
Re: full screen vs. window?
« Reply #1 on: August 05, 2005, 07:13:47 pm »
Chances are the game is trying to send a resolution your monitor doesn't like.  Try setting the resolution in MAME32 config (right click on a game and choose "properties") to as follows:
320x240
400x300
512x384
640x480
800x600
1024x768
1280x1024,
etc
Try several to see what works best with your monitor.
SpeedyR
« Reply #2 on: August 11, 2005, 01:19:59 am »
for whatever reason when I installed mame32 ver 99 it took care of the problems...
I just added an LCD screen so now I have a feeling I"m in for more adjustments. so far so good but I did notice that some of the full screen games were to the left and I know I just read something aobut that  today so off the forums to search for that answer... :)
Jeff
