Author Topic: Mame32 and that crappy ROM LOADING window - How to hide in mamewah?  (Read 1522 times)
darthbane2k
  • Last login:September 30, 2009, 04:54:06 am
  • Built the cab, just need the time to play!
To cut a long story short, I found Snk Vs Capcom Chaos and obviously  have to run it in a special hacked version of mame32.
So that
ahmer
  • Last login:March 16, 2014, 02:40:21 pm
  • Do as you like.
    • IC Markets Rebates and Discount
Re: Mame32 and that crappy ROM LOADING window - How to hide in mamewah?
« Reply #1 on: July 28, 2005, 08:24:00 am »
It isn't a desire to bash people that leads to what I am advising you.
No one will help you if you continously ask about illegel/unofficial mame/Romsets,So please never say anything which directly goes against the mame liscence.
Note my regular version of mame32 does not do this within mamewah when launching a game
Don't use any mame32 version with mamewah,it is not a wise thing because mame32 already contain an integrated/built-inn fronend and if you do that you will lost some CPU and Memory efficiency.
just compare the size of regular mame and mame32 Exe files.
darthbane2k
« Reply #2 on: July 28, 2005, 09:14:08 am »
okay okay the issue ISNT the hacked mame and svc chaos roms (Although dont act like im the only one who's used this!)
The issue is the now loading box.
I dont see why mame32 isnt advised? its the SAME as Mame, you can even run command parameters/switches on it.
As for CPU usage, it hardly uses anymore than regular mame on my system.
Can anyone else help?
« Reply #3 on: July 28, 2005, 11:17:05 am »
You can try using the {nodosbox} flag in your mamewah commandline_format...it might work.
FYI You could try being a bit more subtle about what you're doing...you might get a better response.
