Author Topic: Football Champ/ Hat trick hero  (Read 10623 times)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
« on: July 22, 2005, 06:11:00 am »
Im not sure if this is the right place to be posting this so if not i apologise.
Im curious to know if anyone knows how to perform the super shot on this game i have seen screen shots of this but have never been able to do it and iv played the game religiously and tried many combos.
Anyone know how?
Dagg
  • Last login:June 05, 2017, 04:23:59 pm
Re: Football Champ/ Hat trick hero
« Reply #1 on: July 22, 2005, 08:56:17 am »
Best I could find was this, even gamefaqs doesnt have much:
TAITO POWER GOAL / HAT TRICK HERO 95
- Buy hyper shoot or super shoot (push button 3 when you see 'press "C" button').
- Pass the ball using button 2. (you must do this one or more times).
- You can shoot free super shoots when time left is less than 30 seconds.
(IMG:http://images.webmagic.com/klov.com/images/10/1093727590.jpg)
SUPER CUP FINALS (*)
- Buy hyper shoot or super shoot (push button 3 at the beginning of the match or when you see 'press "C" button').
- Pass the ball using button 3. (you must do this 2 times).
- You can shoot free super shoots when time left is less than 45 seconds. To do that, you must pass the ball to the player you chose at the beginning of the match using button 2.
- If time left is less than 30 seconds AND the result is a draw, you can shoot a free hyper shoot. To do that, you must pass the ball to the player you chose at the beginning of the match using button 2. (it's pure luck)
(*) You can use this in 'Taito Cup Finals' , 'Hat Trick Hero 93' , 'International Cup 94' and 'Hat Trick Hero 94'.
FOOTBALL CHAMP / HAT TRICK HERO / EURO CHAMP 92
- Super shoot only happens in the last 30 seconds, if you are losing by 1 goal or tied, and only when the team member you chose to play with kicks it.
(IMG:http://images.webmagic.com/klov.com/images/10/1078697591.jpg)
Not sure if it helps as I never played it.
Dagg
Dagg
« Reply #2 on: July 22, 2005, 09:01:46 am »
Actually after a bit more digging I found this as well:
 single player or a joint team uses the World Cup team of their choice to try to defeat another in a timed period. The team moves on to the next team if they were victorious. The game has 7 levels, you can choose your next rival, but the last one is always the same. To make it easier, you can use special shoots spending one or more units. You get extra units when you win matches; or you can buy more by inserting coin(s) and pressing the 1 player button - if you are using that player.
Tips for special shoots: - The best shoot is the hyper shoot, it's unstoppable. The best moments to use that shoot are at the beginning of the final or when time is almost up and you need a goal to win. - If you use the super shoot, the goalkeeper can avoid the goal -but sometimes he can't and ends inside the net :) or scores an own goal-. - To show the menu with the special shoots, push 'button 3' when you see 'Push C Button' -if you haven't done at the beginning of the match-. You choose one pussing 'button 3'. - To activate the shoot use the 'button 3'. (to activate hyper and super shoot you must do that twice, the first time you pass tha ball to another player and the second time activates the shoot).
Know anything more about this game?Click here to contribute a description or other text information.
Cheats, Tricks and Bugs
Sometimes, the player you chose when you started to play can make super shoots. It happens only once per match and when time left is less than 45 seconds. This is random, but it seems this can happen when you pass the ball to that player using Button 2.
Tip 1: You can make a free hyper shoot *only* when the result is a draw and time left is 10 seconds or less. To activate it, you must pass the ball to the captain using button 2.
Tip 2: You can make a free super shoot when time left is 30 seconds or less. To activate it, you must pass the ball to the captain using button 2. But this time the result doesn't mind (You can do it when you are 0-0, winning, losing,....).
Marky_1979
    • Personal Webspace
« Reply #3 on: July 22, 2005, 09:02:23 am »
Cheers Dagg i couldnt find anything on this so its nice to have something to work on. If thats the case then i still need to work out how its done
Marky_1979
    • Personal Webspace
« Reply #4 on: July 22, 2005, 09:05:59 am »
Has anyone managed this ? as the game only has two buttons there is no third?
