Author Topic: What kind of Power Supply do I need?  (Read 1131 times)
USSEnterprise
  • Last login:October 11, 2007, 11:15:08 pm
    • USS Odyssey
« on: July 22, 2005, 02:06:29 am »
I just bought a set of matched Xeon processors on eBay, each running at 1.4GHz. The motherboard's manual that I bought says at least a 400 watt power supply is needed to insure system stability, but it needs an extra power connector to the motherboard. Can anyone help?
Proper capitalization is the difference between helping your Uncle Jack off a horse, and helping your uncle jack off a horse.
cdbrown
  • Bowowow
Re: What kind of Power Supply do I need?
« Reply #1 on: July 22, 2005, 02:27:56 am »
I guess it has 3V, 5V, and 12V 24-pin ATX power connector (normal connector) & 12V 8-pin connector (the one you're not sure about).  Means you need a EPS12V type power supply.  I recommend Antec type power supplies as they haven't failed me at all. But they have a big 550W PS in that form.  Look around on your online shops to see if they have a different brand with EPS12V
