Author Topic: Measuring Help  (Read 1362 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
Measuring Help
« on: July 20, 2005, 06:11:15 pm »
Ok, I'm almost done with my cab.
toolaa
  • Last login:April 04, 2024, 02:03:09 pm
  • Work In Progress...
    • Moon Patrol Project
Re: Measuring Help
« Reply #1 on: July 20, 2005, 06:35:12 pm »
Which game was the cabinet from?
Does the control panel have a hinge on the bottom edge and tilt out when unlocked?
Does the glass at the top of the bezel fit into some slot or opening under the marquee?
Super Sprint - In Progress ($150)
Moon Patrol MAME - Completed ($670)
Tic-Tac-Strike Puck Bowler - Restored ($1200)
First Time Visitors Say "Holy Cow!"
. . . . . .Priceless
tkuper05
Re: Measuring Help
« Reply #2 on: July 20, 2005, 06:52:03 pm »
It was a Mat Mania.  I fabricated my own CP.  The CP does have a hinge and tilts outward.  There is no slot yet for the plexi.
Bill Mote
  • Last login:May 29, 2010, 11:04:28 pm
  • Focus on making things better not bigger.
    • Things That Make Me Mad and How To Fix Them
Re: Measuring Help
« Reply #3 on: July 20, 2005, 08:30:12 pm »
If you're really worried about the measurement and you can't get a tape measure in there well enough use twine, fishing line, or weedeater string.  Don't use regular old kite string as it will stretch.
Have some one hold the string and then mark the bottom and top.  Then just measure between the marks.
dot
DrewKaree
  • HAH! Nice one!
    • A lifelong project
Re: Measuring Help
« Reply #4 on: July 21, 2005, 01:21:21 am »
Go get yourself a FOLDING tape measure.
If you can't measure with THAT thing, your cab is simply going to fall apart anyway ;D
Avery
  • Last login:May 03, 2013, 12:52:02 am
  • Have fun! Make stuff.
Re: Measuring Help
« Reply #5 on: July 21, 2005, 12:33:14 pm »
I've got a situation kind of like the one you describe (no clear reference point to measure to) so I'm using a piece of masonite as a surogate pane of glass.
In your case, I'd cut a strip of the stuff a few inches longer than you need and start hacking off bits until it fits the way you want it, then measure your strip of masonite.
Avery
DrewKaree
  • HAH! Nice one!
Re: Measuring Help
« Reply #6 on: July 21, 2005, 04:11:24 pm »
For those who wonder "WHENTF would I ever use one of THOSE?" now you know.  These DO have their uses, and this is a case of one of those times
