Author Topic: Anyone here already build converted a driving cab?  (Read 2011 times)
arcadepcnut
  • Last login:August 15, 2019, 12:03:07 pm
  • Warhammer 40K, you should try it.
    • BREAKTIME
« on: December 23, 2002, 12:16:10 pm »
I'd like some websites or info from anyone who has done a sitdown (or standup) driving cabinet. Any and all details you are willing to provide will help!
Thanks in advance.
Tiger-Heli
    • Tiger-Heli
Re:Anyone here already build converted a driving cab?
« Reply #1 on: December 23, 2002, 10:57:21 pm »
Thanks in advance.
Two great sites are:
http://www.gunpowder.freeserve.co.uk/wheels
and
http://www.theuspits.com/hardware/lew/index.html
They both deal more with BYOAC for PC racing games than MAME, but the info is excellent.
generousben
  • Last login:May 17, 2003, 11:45:43 am
« Reply #2 on: December 24, 2002, 09:40:05 am »
Theres a few things about converting a driving cab,
first you really need to make it  compatible with both,
360 and 270 wheels.
I just had 270 and its a bit anoying only playing half the games.
Its not that hard to get the original arcade wheels to work,
to get a 360 to work u just need a simple mouse hack,
the good thing about the 360 wheel is its easy to change the sensitivity  and speed of a mouse.
the 270 is fairly simple also ,just make/hack 2 button joystick lead the same as the diagram on the web sites.
the  only thing about the using a joystick hack as a steering wheel is u are just using a standard joystick driver.
what i found was that in the some  mame games like chase hq , when you went into the dip switch setting in the options you could select digital or analog steering .
where as in outrun you couldnt.
chase hq worked fine where as outrun wasnt so good.
(im sure it would work fine if more time was taken)
for the 270 wheel it might be easyer to use the insides of a pc wheel so you get a beter software driver.
I never spent that much time on it though as i havent got a spare pc for a dedicated mame driving cab.
« Last Edit: December 24, 2002, 10:10:18 am by generousben »
SNAAAKE
  • -Banned-
« Reply #3 on: December 25, 2002, 04:22:46 am »
is it possible to hack these wheels for PS 2 and dreamcast and such?
any possibly atleast? ::) ???
