Author Topic: Lethal Enforcers II reload?  (Read 6323 times)
GameOver
  • That's right. I'm Abe Froman.
  • Last login:February 11, 2013, 06:54:31 pm
  • Got a quarter?
    • Check out my cab!
« on: July 18, 2005, 07:04:06 pm »
I played Lethal Enforcers II for the first time the other day.  I was having a good 'ol time until I needed to reload...normally I just move the cursor off-screen (I use either the joystick or t-ball, no gun yet).  That seems to work in the other shooting games, but didn't for Lethal Enforcers II.  Did anyone else have this problem?
Until then I only get 6 shots then I'm toast!  Help!   8)
Marky_1979
  • Last login:January 03, 2017, 11:07:07 am
    • Personal Webspace
Re: Lethal Enforcers II reload?
« Reply #1 on: July 18, 2005, 07:55:46 pm »
i could be  wrong but i think in the mame config ini you can select an option that will automatically reload for you on these games. i WILL TRY THIS OUT AND SEE IF IT WORKS
Marky_1979
    • Personal Webspace
« Reply #2 on: July 18, 2005, 08:09:29 pm »
WELL I TRIED THAT AND IT DIDNT WORK :( SORRY MATEY I TRIED
vibez
  • Last login:February 09, 2011, 08:33:20 am
« Reply #3 on: July 19, 2005, 06:34:28 am »
It is a known bug.
Here is a quote from MAWS
In le2 is now impossible to reload. The off screen reload area has slowly gotten smaller and smaller through more recent versions of MAME. I shot everywhere along the edge and in no place would it allow a reload of the gun, so the game is unplayable after emptying your first round unless you have cheats on. le2085u2gra Karasu
Looks like the cheats will get around the problem
GameOver
  • Got a quarter?
    • Check out my cab!
« Reply #4 on: July 19, 2005, 01:45:12 pm »
Thanks.  I've never used cheats.  How do they work??
MKChamp
  • Last login:December 24, 2025, 01:30:45 pm
  • Stil around.
« Reply #5 on: July 19, 2005, 04:56:25 pm »
You need a cheat.dat file which you can get here...
http://cheat.retrogames.com/
Drop that in your mame folder and then access the menu while the game is loaded (tab by default).
From the select enable/disable a cheat and turn on the one you want!
