Author Topic: Mamewah Game Lists  (Read 2553 times)
ponyboy32
  • Last login:February 04, 2010, 01:28:01 pm
Mamewah Game Lists
« on: July 18, 2005, 06:38:43 pm »
I have a bunch of roms for mame and I plan on using Mamewah for my cabinet. The zip files of my roms have shortened names, ie. bbros.zip; bstars2.zip; etc.
I want the full game name to show up in the list in Mamewah so I know which game it acutally is. Is there a way to generate a list of complete names even though I have the files with shortened names? My lists always end having the same name as the .zip files.
giza
  • Last login:November 12, 2005, 08:52:17 pm
Re: Mamewah Game Lists
« Reply #1 on: July 20, 2005, 08:34:05 pm »
I'll try to answer this the best I can.  Find the latest version of catver.ini from http://www.catver.com/downloads.html.  Put the catver.ini in the root of your mame folder.  The catver will allow you to filter by category.  To get the complete file name, you will have to generate a .dat file of the roms you have.  I think the command to generate a .dat file is mame -listinfo|xml2dat > mame.dat.
Once you have the .dat file, use mamewah config to generate your lists.  Sorry not too much detail, but hopefully this will get you in the right direction.
« Reply #2 on: July 21, 2005, 06:09:52 am »
Use the default settings in \mamewah\ini\mame.ini .  You must have changed the list_generation_method to rom_folder in order to get your shortnames to appear - everyone has short romnames for MAME so I purposely set the correct list_gen_method ;)
« Reply #3 on: July 21, 2005, 06:12:03 am »
Correct, but this is not required to generate a games list.
Part right...you can do this and use a dat_file list_generation_method.  However the default (listxml_vs_rom_folder IIRC) is easier as you don't need to create a dat file yourself.
It is probably easier to just hit Games List Options > Generate List in Mamewah.  Unless you are already using Mamewah Config that is.
