Author Topic: Spinner & Trackball Issues  (Read 1907 times)
slayj
  • Last login:January 10, 2006, 02:49:56 pm
  • Anybody seen my joy...???!
« on: July 14, 2005, 09:43:10 pm »
I have a trackball and spinner connected via USB in Windows XP.  I assume the default mouse is the trackball because any game that uses a spinner or trackball is only working with the trackball.  If I go into the Mame controller menu and select the input device, how do I tell it to use the spinner?  If I move the spinner nothing happens. Can this be done within the main Mame32 GUI, and if so where?
Did you know if a frog had wings it wouldnt bump its butt!!!
slayj
Re: Spinner & Trackball Issues
« Reply #1 on: July 14, 2005, 09:58:18 pm »
Once again..........I'm an idiot.  Seems XP isnt registering my spinner.........thats why I couldnt select it..... :-\
forbiddenlyrics
  • Last login:July 10, 2010, 03:19:34 pm
  • I'm Bart Simpson Who The Hell Are You?
« Reply #2 on: July 14, 2005, 10:17:25 pm »
Would it have something to do with the fact that XP doesn't support two mice?
slayj
« Reply #3 on: July 14, 2005, 10:18:36 pm »
XP supports two mice....and it is now working
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: July 15, 2005, 01:24:38 pm »
.... the fact that XP doesn't support two mice?
Both statements are true (in english, at least).
It's due to the fact that "mouse" and "mice" can mean different things.  "This mouse works on any surface" refers to the physical mouse device, while "Move the mouse over the button" refers to the pointer on the screen.
"XP doesn't support two mice (mouse pointers)."
"XP supports two mice (mouse devices)."
No conflict, both true.  So why does this matter?
Mame needs to see the each of the mouse devices data as seperate to support two/multiple "mice" ;), and having XP support two pointers would be the most straight forward way.  But pointers are not the only mame/applications can do this, so "mouse" has a third meaning in the context of "does mame support two mice?"; this meaning isn't seeable or touchable, so it's harder to describe.  "Mouse instances" or "mouse data streams" are probably the best terms for this meaning.  XP doesn't support two mouse data streams navtively (win32 api) or through directX, but it does through RawInput.  (mame doesn't use RawInput)
Okay, to review:
"XP doesn't support two mice (win32 api)."
"XP doesn't support two mice (directX)."
"XP supports two mice (RawInput)."
"Mame uses directX for trackball, and win32 api for lightgun."
"AdvanceMame can now use RawInput."
"MameAnalog+ ver. 0.84 could use RawInput."
I hope this clarifies more than it confuses. ;)
Robin
Knowledge is Power
