Author Topic: WG U2000 Brightness Problem  (Read 2413 times)
wakeup
  • Last login:September 25, 2014, 01:31:29 pm
« on: July 14, 2005, 03:42:12 pm »
This is my first arcade cabinet and I am having problems with the monitor.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
Re: WG U2000 Brightness Problem
« Reply #1 on: July 14, 2005, 04:11:18 pm »
I'd start with a capkit.  It's also possible that the tube is going bad.
Best,
 - Mike -
wakeup
« Reply #2 on: July 14, 2005, 05:35:35 pm »
I've already installed a cap kit.  33 Capacitors in total.  No change.  If its the tube thats going then I pretty much need a new monitor, right?
pcb
    • MikesArcade.com
« Reply #3 on: July 14, 2005, 06:05:04 pm »
Possibly, or if you can find a TV repair shop that still does Tube rejuvination, you can try that before getting a new one.  If you do buy a new monitor, keep your chassis and yoke off the old one to use as ebay fodder. :)
 - Mike -
wakeup
« Reply #4 on: July 15, 2005, 09:50:53 am »
I've contacted a local TV repairman who can do a tube rejuvenation in my home for $55 CDN tax in (approx $45 US).
Ken Layton
  • Guru
  • Technician
« Reply #5 on: July 15, 2005, 10:26:00 am »
Sounds like a tube problem. It should be fixed with a rejuvenator.
