Author Topic: bagman what monitor to use ???  (Read 2230 times)
arcadefever
  • Miami Beach Florida
« on: July 13, 2005, 12:00:13 pm »
hi,
i`m restoring a bagman game and i've problem to adjust the monitor the graphics are not that good some weird vertical line apears, i use a new monitor , when i plug the game in my 6 other cabs same thing happen exept in the bad dudes cabinet  ???
do some game work better on some monitor ???
thanks
Ken Layton
  • Guru
  • Technician
Re: bagman what monitor to use ???
« Reply #1 on: July 13, 2005, 12:40:31 pm »
Bagman used a conventional horizontal shelf mount monitor mounted vertically. I believe they were originally shipped with Wells-Gardner k4900 series monitors.
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #2 on: July 14, 2005, 04:40:36 pm »
I'm not sure about this, but it's possible that Bagman had POSITIVE sync instead of the normal negative sync.  You might try using the positive sync inputs on the monitor to see if it makes a difference.
Best,
 - Mike -
arcadefever
« Reply #3 on: July 14, 2005, 07:11:54 pm »
Best,
 - Mike -
thanks mike , just one thing wher can i found the positive sync  :-\ on the monitor ?
anyway when i try the board on bad dudes it work and bad dudes use negative sync .
pcb
    • MikesArcade.com
« Reply #4 on: July 15, 2005, 01:20:51 am »
There is usually a 2nd set of sync inputs.  It depends on your monitor.
If the board syncs in the Bad Dudes cab, maybe your other cabs don't have a good video ground?   I'm just guessing here, since I don't know what monitor your using, or how they are wired.
arcadefever
« Reply #5 on: July 15, 2005, 10:32:52 am »
i think that the problem the video ground  :-\
thanks for the help
arcadefever
« Reply #6 on: July 18, 2005, 03:00:44 pm »
hey PCB
thanks so much for telling me to check the video ground. on bagman the setup is a little diferent the video so i check it up and try something and it is working perfectly . thanks for the tips
fred
unix4hire
  • Last login:October 16, 2008, 06:12:47 pm
  • activate interlocks...
    • My Business
« Reply #7 on: July 18, 2005, 04:54:26 pm »
You're restoring a bagman?   That's great, I haven't been able to find one since the only one I saw about 18 years ago in a laundromat my folks owned.  Damn, too bad I didn't have them keep the games before they sold the joint.  Good luck, send a pic when it's complete if you don't mind.
--Erich
pcb
    • MikesArcade.com
« Reply #8 on: July 20, 2005, 03:41:40 pm »
hey PCB
Glad you got it figured out. :)
Best,
 - Mike -
