Author Topic: "TAB" key won't work to enter setup menu  (Read 3332 times)
Extreme8
  • Last login:August 24, 2008, 03:46:24 pm
« on: July 11, 2005, 07:10:24 pm »
I've just discovered that my tab key no longer works to enter the setup menu in MAME .97.
When I press it I see the setup menu flash and then I get the volume control. If I continue to press tab the setup menu keeps on flashing but never stays up.
I know the tab key is working - I've tested it in Wordpad and in some other emulators (mess, etc). I've tried 2 keyboards and the shifted function of the Ipac all with the same results.
I'm probably missing an ini/cfg file but I can't see anything missing.
Any help is appreciated.
2600
Re: "TAB" key won't work to enter setup menu
« Reply #1 on: July 11, 2005, 07:26:18 pm »
Try deleting your default.cfg in the MAME\cfg directory
Extreme8
« Reply #2 on: July 11, 2005, 09:29:49 pm »
You nailed it. Works like a champ.
Thanks.
SirPeale
  • Green Mountain Man
« Reply #3 on: July 11, 2005, 10:02:24 pm »
Yeah, that one comes up a lot.
Try doing a Google search for it.  Happens pretty often.  It's even in the Mame FAQ.
