Author Topic: Happ buttons common ground  (Read 1185 times)
tkuper05
  • Last login:February 20, 2022, 07:57:24 pm
  • I find your lack of buttons disturbing.
« on: July 11, 2005, 06:22:57 pm »
Ok, I'm not the most knowledgeable when it comes to electronics.  I have some Happ's microswitch buttons.  There are 3 terminals, 2 for the switch and one for the common ground.  I hacked a gamepad and that's where my buttons are going to be run from.  Do I piggy back all the common grounds for all the buttons then connect that to the common ground on the gamepad?
pointdablame
  • Last login:April 01, 2026, 10:20:52 pm
Re: Happ buttons common ground
« Reply #1 on: July 11, 2005, 06:44:47 pm »
yup.  Most peopel will make a ground loop using all the COM posts on the buttons and the encoder or gamepad ground.
first off your and idiot
RacerX
  • Last login:April 25, 2024, 04:53:33 pm
  • Longtime member, sometime poster.
« Reply #2 on: July 11, 2005, 06:53:11 pm »
Yeah, that's something I would change about my panel if I had it to do over again.  I wired all of my grounds separately to ease in troubleshooting, but I've never had a problem with my panel so I haven't had to do any troubleshooting.  But I'm not complaining about that, either!   :)
